- From: Caitlin D'Abrera <Caitlin.Dabrera AT anu.edu.au>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] firstorder accessing unwanted axioms in Psatz
- Date: Fri, 25 Jan 2019 06:14:25 +0000
- Accept-language: en-AU, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Caitlin.Dabrera AT anu.edu.au; spf=Pass smtp.mailfrom=Caitlin.Dabrera AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi all,
I have noticed some peculiar behaviour with tactics like firstorder and was hoping for an explanation.
I had been using firstorder with expressions that involve standard library nat as well as my own definitions. I noticed the following:
1) When I had "Require Import Psatz", sometimes firstorder would use a bunch of axioms (as displayed with "Print Assumptions my_lem.") As far as I can see, all the axioms are easily provable with e.g. nat and lt, gt, plus, etc.
2) If I don't import Psatz, firstorder either doesn't alter the goal or it does without using the aforementioned axioms.
MWE: https://gist.github.com/caitlindabrera/0a9c43c919352101718dadc08f32609a.
I don't want to be relying on these axioms, particularly because I don't need them. I've found a workaround for my current context: use "Require Import Lia" instead of Psatz, which allows firstorder to work with similar strength as before but without having
access to Raxioms.
I am still puzzled though; why would Psatz use the axioms in Raxioms when they're so obviously provable (and I think all proven elsewhere for nat)? R seems to be modelling reals (not nat) so why is it being called upon in my context, which doesn't use reals, at all?
Best regards,
Caitlin
- [Coq-Club] firstorder accessing unwanted axioms in Psatz, Caitlin D'Abrera, 01/25/2019
- Re: [Coq-Club] firstorder accessing unwanted axioms in Psatz, Florian Steinberg, 01/25/2019
- Re: [Coq-Club] firstorder accessing unwanted axioms in Psatz, Laurent Thery, 01/25/2019
- Re: [Coq-Club] firstorder accessing unwanted axioms in Psatz, Tej Chajed, 01/25/2019
- Re: [Coq-Club] firstorder accessing unwanted axioms in Psatz, Florian Steinberg, 01/26/2019
