- To: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] goal selectors; tactic expressions
- Date: Fri, 25 Jan 2019 13:57:21 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-SY3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
On 01/26/2019 12:46 AM, Jason -Zhong Sheng- Hu wrote:
> It's strange that solve_eqs can succeed twice but repeat fails to
> execute it more than once. You can try in the first goal `repeat
> solve_eqs` only and see if it solves the goal.
No, it doesn't. As I have been led to expect, it does exactly the same
as 1 : repeat solve_eqs. (see below).
> How's solve_eqs defined though? There seems like some problem with it.
I don't see why you should suggest that. Anyhow, it's not the point of
my question, which was how to repeatedly apply a (any given) tactic to
all current subgoals.
Cheers,
Jeremy
> *Sincerely Yours,
> Jason Hu*
> *From:*
> coq-club-request AT inria.fr
> <coq-club-request AT inria.fr>
> on behalf
> of Jeremy Dawson
> <Jeremy.Dawson AT anu.edu.au>
> *Sent:* January 25, 2019 8:37 AM
> *To:*
> *Subject:* Re: [Coq-Club] goal selectors; tactic expressions
> Hi Jason,
> No, I used { on a subgoal, which subsequently gave two subgoals at the
> point at the start of the output shown in my email below
> Cheers,
> Jeremy
> On 01/26/2019 12:32 AM, Jason -Zhong Sheng- Hu wrote:
>> Are you in an assert or something? all: won't catch a goal that is not
>> visible in the current scope.
>> Thanks,
>> Jason Hu
>> On Jan 25, 2019 08:19, Jeremy Dawson
>> wrote:
>> Hi Gaëtan,
>> all: repeat solve_eqs
>> doesn't succeed, I don't know exactly what all : repeat solve_eqs does
>> (previous emails addressed this question and the answer I was given)
>> though in this case it's consistent with applying
>> 1: repeat solve_eqs (which leaves one subgoal, so subgoal 2: is the
>> original subgoal 2)
>> then applying 2 : repeat solve_eqs.
>> or maybe just
>> 1: solve_eqs. then 2: solve_eqs. (ie without "repeat", I can't tell)
>> It doesn't go back to try 1 : solve_eqs again.
>> eg see the following, where the
>> second application of the tactic
>> makes progress beyond the results of the first application of it.
>> 2 focused subgoals
>> (shelved: 5)
>> V : Set
>> Φ2, Ψ1, Ψ2, Γ1 : list (PropF V)
>> Q : PropF V
>> sel1, l, l1 : list (PropF V)
>> ((Γ1 ++ Q :: sel1) ++ l ++ Φ2, Ψ1 ++ l1 ++ Ψ2) =
>> (?Γ1 ++ ?Q :: ?Γ2 ++ ?Γ3, ?Δ)
>> subgoal 2 is:
>> G ++ (?Γ1 ++ ?Γ2 ++ ?Q :: ?Γ3, ?Δ, d0) :: H6 =
>> G ++ ((Γ1 ++ sel1) ++ l ++ Q :: Φ2, Ψ1 ++ l1 ++ Ψ2, d0) :: H6
>> gen_moveL < all : repeat solve_eqs.
>> 1 subgoal
>> V : Set
>> Φ2, sel1, l : list (PropF V)
>> sel1 ++ l ++ Φ2 = (sel1 ++ l) ++ Φ2
>> This subproof is complete, but there are some unfocused goals.
>> Try unfocusing with "}".
>> Cheers,
>> Jeremy
>> On 01/25/2019 08:53 PM, Gaëtan Gilbert wrote:
>>> Note that repeat runs the inner tactic focused on each goal separately
>>> so "repeat (all: solve_eqs)" would (if the syntax allowed it) be the
>>> same as "repeat (only 1: solve_eqs)" which is also the same as "repeat
>>> solve_eqs", and "repeat (only 2: solve_eqs)" is the same as "repeat
>>> fail" ie idtac.
>>> I feel like "all: repeat solve_eqs" should work given what you describe,
>>> can you explain how it fails?
>>> Gaëtan Gilbert
>>> On 25/01/2019 06:54, Jeremy Dawson wrote:
>>>> Hi Cyprian,
>>>> What I wanted is what I would express as
>>>> repeat (all : solve_eqs)
>>>> but it seems as though that form is forbidden.
>>>> The various things I tried as indicated in my earlier email were simply
>>>> looking for alternatives that work.
>>>> Detailed background to what I want: solve_eqs doesn't seem to enlarge
>>>> the number of goals in the cases where I want to use it, and sometimes
>>>> solves a goal, sometimes only after solve_eqs has instantiated an evar
>>>> in another goal, sometimes only after being repeatedly called on the
>>>> same goal (where each time it simplifies the goal)
>>>> Cheers,
>>>> Jeremy
>>>> On 01/25/2019 10:00 AM, Cyprien Mangin wrote:
>>>>> What you probably meant is something like "all : repeat solve_eqs"
- Re: [Coq-Club] goal selectors; tactic expressions, (continued)
- Re: [Coq-Club] goal selectors; tactic expressions, Cyprien Mangin, 01/25/2019
- Re: [Coq-Club] goal selectors; tactic expressions, Jeremy Dawson, 01/25/2019
- Re: [Coq-Club] goal selectors; tactic expressions, Gaëtan Gilbert, 01/25/2019
- Re: [Coq-Club] goal selectors; tactic expressions, Jason -Zhong Sheng- Hu, 01/25/2019
- Re: [Coq-Club] goal selectors; tactic expressions, Théo Zimmermann, 01/25/2019
- Re: [Coq-Club] goal selectors; tactic expressions, Pierre Courtieu, 01/28/2019
