- From: Florian Steinberg <florian.steinberg AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why is the signature of sqrt R->R ?
- Date: Sat, 2 Feb 2019 07:14:53 +0100
Hi.
Here is another advantage of the choice to have the functions be defined on all of the reals and have lemmas that explicitly the values have certain properties: It means that you have very few different types involved that have potentially inconsistent naming systems for their lemmas, which can be a hassle. And, as you've probably already noticed, you can conveniently dismiss most of the additional goals that are generated by a use of lra.
Unfortunatelly, this approach also has some non-straight forward negative consequences. Here are some problems that I believe exist due to this choice of conventions and that gave me some headaches recently:
- The Mean Value Theorem in the standard library is currently formulated in such a way that it takes a function on the reals and an interval [a,b] and you have to prove that the function is differentiable in any point of the interior and that the end points a and b are points of continuity. The latter seems to assume that functions are constantly extended outside of [a,b]... If your function is not like that, you will have to first modify the function to be able to apply the mean value theorem even though the MVT in its usual formulation (i.e. using continuity on [a,b] instead of continuity on R for each element of [a, b]) could be applied to the restriction of the function to the interval right away. I needed the MVT for an application and ran into this problem. I modified (but also weakened) its statement for that, you can find it in a file called "mean_value_theorem" in the repository "youngsinequaltiy" on my github account if you are interested.
- The Function x |-> |x|^p can be defined via Rpower (Rabs x) p but this will give you a wrong value in zero. (I wanted to use this function to define lp spaces so the value in zero is very important for me). Rpower x y is defined through the exponential function which always returns strictly positive values, so it always takes strictly positive values. Note that this is even-though the function x |-> |x|^p can be continuously extended to 0 in zero 0 for any 0 < p.
And maybe one more thing... Another common workaround for partial functions apart from using total functions, dependent types or option types is to use relations with a proof of determinism. It is often a lot easier to describe the graph of a function and give a proof that it is never the case that two different return values are assigned to the same input, in particular if limits are involved in the definition of a function. If I am not mistaken, Coquelicot makes a considerable effort to prove that the axioms of the reals from the standard library are actually strong enough to allow you to translate from such a relation to a total function, so you can kind of switch back and forth between the concepts ... the convention is to name relation that corresponds to a function named f with is_f and the best example in my opinion is the limit function itself (Joseph already gave a pointer to that) or, if you prefer to have a function R -> R, the definition of the exponential function. The translation between relations and functions is called iota in Coquelicot and you there is a theorem iota_correct that allows you to conclude stuff about the function values under the assumption that you can prove that the value is contained in the domain of the relation (unfortunately the later often turns out problematic constructively as you have to prove an existential statement). This seems to be related to the concepts of multivalued-functions which are very popular in fields like computable analysis and function realizability. The main difference between relations and multivalued functions is how composition works, the one for multi-valued functions is more complicated than the composition of relations which already involves an existential statement ... so this will not completely get you rid of the problems with compositionality that Theo mentioned either. Also functional analysis has some applications for multivalued-functions but I am not sure if that's related.
And finally... Can someone comment on how these problems are dealt with in mathcomp-analysis? I take that it assumes enough axioms, so you do not have to deal with the partial equivalence relations and in my experience math-comp does the consistent naming of lemmas very well, so maybe the combination of these makes the use of dependent types more accessible? But you'd still get the dependent type errors in rewriting, right? There is heavy use of dependent types in mathcomp (ordinals, subgroups, polynomials etc..), so maybe they provide a consistent way to deal with issues of this kind? I am not sure what the current state of the mathcomp-analysis project is, I think it is still in its beta phase or something... but if you want to do classical analysis it might be worth checking out. I mean... you are not using CoRN... you've lost hope for executability anyway, right? Oh, and there was a related question on the ssreflect mailing list recently, so that may be worth checking out.
Best,
Florian
On 01/02/2019 11:54, Théo Zimmermann wrote:
Dear Michael,
This design question is fundamentally the same (but in a more complex
case) as the choice of defining 1/0=0 in the natural number domain.
This is something that incidentally continues to confuse beginners not
just in Coq but in other pure functional languages as well
(https://discourse.elm-lang.org/t/integer-division-by-zero/2923). The
alternatives are indeed dependently-typed functions (as highlighted by
Joseph), but also functions returning values of type option. In both
case, this breaks composability and is thus inconvenient.
The three solutions (dependently-typed functions, functions which
return an option and total functions) are all weird compared to the
usual “undefined” behavior of math. So it seems to me that the ideal
solution would be to actually emulate this “undefined” behavior by
raising an exception. Pierre-Marie Pédrot has worked on adding
exceptions to CIC without breaking consistency and has a plugin to do
that (that I've never tried). I don't know how far we are from having
exceptions in mainline Coq...
Théo
Le ven. 1 févr. 2019 à 10:38, Soegtrop, Michael
<michael.soegtrop AT intel.com>
a écrit :
Dear Joseph,
thanks for the detailed explanation of the design considerations!
So in short the story is that all real functions with domain restrictions are
extended to total functions over the complete R by returning some value which
is convenient in most situations. E.g. for asin I could return –PI/2 or PI/2
for out of domain arguments, so that I can prove that the function is
everywhere continuous and that the result of asin is limited to –PI/2 to PI/2
without requiring domain restrictions. And when it comes to proving that my
definition of asin has a certain taylor expansion or derivative, I limit the
argument range of asin to –1 … 1. Or alternatively I could return 1/0 for out
of range asin, which possibly would allow me to prove that the derivative of
asin x equals 1/sqrt(1-x^2) everywhere, but then I would need a domain
restriction for the lemma which shows that asin x is bounded.
This design leads to that one can prove:
Require Import Reals.
Require Import Psatz.
Open Scope R_scope.
Lemma sqrt_minus_one_is_zero: sqrt (-1) = 0.
Proof.
unfold sqrt.
destruct (Rcase_abs (-1)) as [H|H].
- reflexivity.
- contradict H; lra.
Qed.
I am not sure if I like that one can prove sqrt(-1) = 0, even if this does
not lead to a prove of that x=0 solves x²=-1. It is an interesting system – a
bit weird, but I guess one gets used to it over time. As I said, in practice
the reals as defined in Coq are very convenient to use and I understand that
one has to pay some price for that (like sqrt(-1)=0).
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
- RE: [Coq-Club] Why is the signature of sqrt R->R ?, Soegtrop, Michael, 02/01/2019
- Re: [Coq-Club] Why is the signature of sqrt R->R ?, Théo Zimmermann, 02/01/2019
- Re: [Coq-Club] Why is the signature of sqrt R->R ?, Florian Steinberg, 02/02/2019
- RE: [Coq-Club] Why is the signature of sqrt R->R ?, Soegtrop, Michael, 02/04/2019
- Re: [Coq-Club] Why is the signature of sqrt R->R ?, Richard Ford, 02/04/2019
- RE: [Coq-Club] Why is the signature of sqrt R->R ?, Soegtrop, Michael, 02/07/2019
- Re: [Coq-Club] Why is the signature of sqrt R->R ?, Florian Steinberg, 02/05/2019
