Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop
- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop
- Date: Sun, 3 Feb 2019 01:12:14 +0100 (CET)
----- Jason -Zhong Sheng- Hu
<fdhzs2010 AT hotmail.com>
a écrit :
> Hi,
> Conceptually, when proving one inductively defined Prop from another can be
> considered as a translation between derivation trees. However, I am
> recently running into a problem that, when taking this view, such
> translation does not have to be structural. In particular, sometimes
> generated inductive hypothesis by `induction` doesn't make immediately
> sense, but can be applied to some other derivation trees after certain
> processing, so that some measure can also be applied to argue termination.
> The tricky part here is Prop -> nat is not meaningfully definable type,
> because Prop cannot be eliminated in Type/Set, so even if I know how to
> define measures on paper, I am not able to define one in Coq.
> Is there any way out so that well-founded induction can be done intuitively?
Hi Jason,
I think you basically have two options: putting your derivations in
Type/Set and defining a measure on them or indexing your propositional
derivation trees with their size/depth (i.e nat -> Prop), building in the
measure you want and then showing that some functions are size preserving or
decreasing on derivations. I think the later is a bit more delicate in
general as this forces you to carry around the size information even in
lemmas that have nothing to do with it e.g. by existentially quantifying on
sizes. Also you can always go back to seeing a derivation tree in Set as a
Prop using an explicit squashing operation, if needed. You might have to make
some of your lemmas transparent to show size preservation in the Set case,
but that’s to be expected when you’re really doing proof-relevant reasoning.
My 2 cents,
— Matthieu
- [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Jason -Zhong Sheng- Hu, 02/02/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Fabian Kunze, 02/02/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Jason -Zhong Sheng- Hu, 02/04/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Matthieu Sozeau, 02/03/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Jan Bessai, 02/03/2019
