coq-club - Re: [Coq-Club] [SUSPECTED SPAM] Re: "Sequence is associative." (?)
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] [SUSPECTED SPAM] Re: "Sequence is associative." (?)
  • Date: Sun, 3 Feb 2019 18:53:48 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-vs1-f47.google.com
  • Ironport-phdr: 9a23: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
I opened https://github.com/coq/coq/issues/9462
Best,
Théo
Le dim. 3 févr. 2019 à 15:43, Pierre Courtieu
<pierre.courtieu AT gmail.com>
a écrit :
> Le jeu. 31 janv. 2019 à 01:10, Jeremy Dawson
> <Jeremy.Dawson AT anu.edu.au>
> a écrit :
>> On 29/1/19 3:41 am, Pierre Courtieu wrote:
>> > all:tac. applies the tac to all goals.
>> > Period.
>> Well, IMRO this is pretty unsatisfactory. Since the order of applying
>> tactics (or parts of them) to subgoals matters (as in the case, for
>> example, of instantiating existential variables) you are making it seem
>> that coq's design is so complicated that it is not worth while trying to
>> describe it.
> I don’t know. Maybe the order in which goals are treated should be
> explicited in documentation. Or maybe not. If one wants to force a
> particular ordering then it is possible by focusing.
>> And there is certainly nothing in the documentation, as far as I can
>> see, to explain, or even to alert the user to the fact that
>> all : solve_eqs
>> when there are two subgoals, solves both, whereas
>> all : repeat solve_eqs
>> leaves one of them unsolved
> It is sais in documentation as far as I can tell: « applied to each goal
> independently means that is equivalent to 1:repeat solve_eqs. 2:repeat
> solve_eqs...
> But indeed we need a repeat with the interleaved semantics.
> Can you fill a big report about that please?
> Best regards
> Pierre
>> Cheers,
>> Jeremy
