- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Automation for division over nat
- Date: Sat, 9 Feb 2019 18:20:09 +0100
- Autocrypt: addr=thery AT sophia.inria.fr; prefer-encrypt=mutual; keydata= mQENBE3a3V8BCADTeORKU7I7UmBBcs4VhSCq1IgKD8vdmdrGAlF3IJSFng7Fk8+MgS2gWYcS Ukf5t+rjNM3Z6brfYXc1naZlf2JPGHvAGiz8+TkXL+/ZA6+gAoIKy/iKyD+hCD8m92WH3rPH vCX6EJ44FEI7gUJ37GlTjvuP0I55vaFcwEg8nDgkALaCJvrSHtePuPKR1Q+9q2dgR7fTObal HYGMAsgT6k6n2ofe4Q6VFRLJhruU02qAfV5zgIoa3xgrTwSr4RRDILHttAw7EN6aLG6JycJ7 sPsPsiQzrd/tFsNbiHYeojJCkU2pDSQ3pBtXAJL/z2pMWTeTXvA60l9w0sDO7M3mkC3vABEB AAG0J0xhdXJlbnQgVGjDqXJ5IDxMYXVyZW50LlRoZXJ5QGlucmlhLmZyPokBOAQTAQIAIgUC TdrdXwIbAwYLCQgHAwIGFQgCCQoLBBYCAwECHgECF4AACgkQHHaWvRTi0tpIgggAnSUYcU2N uchXkGGwmPuLmvSUMiLkyFPs9GF2YF1ONOuJtpnQMcpsseCkcmIjESz0h5OpknpyraUXvbh0 ZdFqaLC2E+GyV8/YQi71wSsTPgWP450u0XUt0ysjwkKW6aIxIhSzrtgNp4E6w5KzXVJxA/yM V5RNFHg/5uifgfv4b7xaGHV8L93NbSvedk1O7yje5Hqgfab0t6J5Kf0M3sG+pB3gEkDVK9B7 +0fhe7/5u1Nj5HoLWid8UNZfFzJzb18Xe2ckzNye0KdDtQFac8qGUzhLbEYt3ScYjRYTq9/d V4Cin39j7Oo64Nk71iiLBISyuk0Q9D+Jq7nwwcQr/R8s1rkBDQRN2t1fAQgA7H6aX6BfdO/X Vlf4EGEoyFQ5u/JDe+giIHWSS34YWDWVUYyp320CrAYAkh9lQ1Nvh1tsmgiUh5xnY7wY0tOi wJSm94XlYAmHrddmWVNXRn09GvZJhfI2LdVBg3oxPfc8+bV+Hz83z/5BMPLOogxB22QMPJ6e iD2EsUMPNsuCVQ8WNo6ZmueuuYe7vEUXLYdRXNumJJgekEuG/q1BD4xgfzWpWfUODm6WygWZ oov50DomcDcAHW03bgnHlqnYu20Qg00GqgR3FKlORTvnOxD5TMCXe+eLUxkQfvnjbIPhtrnJ hgJMKVkRBEoaQ/XA4FdvxloInYPbqxNZ72yd09BbewARAQABiQEfBBgBAgAJBQJN2t1fAhsM AAoJEBx2lr0U4tLaWNQH/2/fIaF9ngbKPBJbDxYa7glJuCfamJgy3R8mJ//VYsS4RbdroSX3 29EgWlTx2reu1b4C5n5k7l4KpLgsRIc3bLUasGv15nf8BqmKIMulidzsxJv86S2imY/0870Q NOiO9SElHE7/2q4J1m2ew77SegiqGVWHl6Zs+4ROfOILTy24o26BQMAZhPX7jEs04Atv6yjw OUIPbzFO+XRuKqkBwHn9S8+GQelT0Gh84Dc5D2jIF0+kWY7uHqe2O+2LPfgO2CYhqmVfr/Ym mZv2xUyhJ7gui2hYaggncQ96cM2KhnKlgMw8nStY0GTqVXLEjPYblz8mqtF8aBPRSk/DjjrF QeI=
- Openpgp: preference=signencrypt
On 2/9/19 3:43 PM, Gert Smolka wrote:
> Is there tactic support for proving lemmas involving division over nat, for
> instance
Unfortunately, it seems you need to populate the assumptions with
instances of Nat.div_mod and Nat.mod_upper_bound for nia to do
something.
Here is how you can solve "automatically" your 3 examples:
Require Import Psatz.
Require Import Arith.
Lemma bound_nat a b :
(b = 0 /\ a / b = 0) \/ (0 < b /\ a = b * (a / b) + a mod b /\ a mod b
< b).
Proof.
destruct b; [left | right].
now destruct a; simpl; lia.
repeat split; try lia.
apply Nat.div_mod; lia.
apply Nat.mod_upper_bound; lia.
Qed.
Ltac rm_div :=
match goal with
|- context [ ?a / ?b] =>
let tmp := fresh "Hl" in
let u := fresh "dd" in
let v := fresh "mm" in
assert (tmp := bound_nat a b);
set (u := a / b) in *;
set (v := a mod b) in *
|- context [ ?a mod ?b] =>
end.
Ltac dnia := repeat rm_div; nia.
Goal forall k x, 1 <= k <= x -> x / k >= 1.
intros.
dnia.
Qed.
Goal forall k x y, x <= y -> k >= 1 -> x / k <= y / k.
intros.
dnia.
Qed.
Goal forall k x, k >= 1 -> (k * x) / k = x.
intros.
dnia.
Qed.
- [Coq-Club] Automation for division over nat, Gert Smolka, 02/09/2019
- Re: [Coq-Club] Automation for division over nat, Laurent Thery, 02/09/2019
- Re: [Coq-Club] Automation for division over nat, Bas Spitters, 02/09/2019
- Re: [Coq-Club] Automation for division over nat, Gert Smolka, 02/09/2019
