coq-club - Re: [Coq-Club] generalized rewriting question
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] generalized rewriting question
  • Date: Mon, 18 Mar 2019 11:41:23 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-it1-f175.google.com
  • Ironport-data: A9a23:tHkY7q85ysBcyLz3K0DXDrVtTnXE1WbSOkUsXfhEv+u59PezSZTTRX KfIqLkArLTjdfnxnRn6lgTIQ5le1f4Oz/H3eLihdTo69a7ovln3aQqDsx/VgyAHrmKgpiaOp g1WeSr96R2+/8eTMnxb39ya7NTQsudV8IxpMPr96UAjmgbNcLXtL5Uc5u+74UgESbgglzQkD fgT4h5u4WsJ5alxkzRTdrJOsKWSIs2wObsgKNmznku8M1TF7L/HT5uk3ryHgTl7QrL3lXjBj orJihPA7fSlUfWE2peyJmjPcGi4RvkKaRihQiqVdBRxd5bz9fqnpl8P2CSSadXt4kyFShj8x 22ussI5zkYzArNbKzlxJ9u6G616tx1W93XPCM2FBzOKDizryRLM4GQRPGTrW5RQ4ZBVKMB8u XInBOdUGoLoZrzHQPaxMUZXsfhiMzwIxR7SlmlZBzNHU1/qbZcChRZmcDfq3tCbzhUMkx+k3 uAsncVKCYtuIQ0g32WLqVeUB2Hnk/DaYfYXgoMakPo/jHBm14xkIkVQtqc005Ahqbjwis1hw i2AlNCq9bB4WVgSof9MrpS5cWvTDGeOYsHYqbgHQNwqr5ZQd/FhThzsMeybWryhbMej5cmFc /jHOJrzAYbsaeadMWxbJaPV/7wUZEMqqRlm5kClypFryCdT9RgObZ/Yy3MO+L+dwcx9GGPC5 Omitb2QrP6P7wCxKIKNGCBWrdV4f8P8+T1yXKHKAWHLCefNigf8MSaxyqEMJSqUoMOiMnLt3 vTbx4Bt/xw060bB2oKGNlTSCCGUA9wppZelnITfJ1INnCoTbbuLSYBmCwS8inSiBrylabmUi 8OY86AsIIZRYhlrmqk1zKRF6IrlUmurhLuAYa9JNQuoIMrjVhbXbqjK/gpl493wTuTIF+XRa 0tkRU65aahma7GBcc=
  • Ironport-phdr: 9a23:kEzRZxB5almT1F5Cs7wvUyQJP3N1i/DPJgcQr6AfoPdwSPT6rsbcNU DSrc9gkEXOFd2Cra4d06yO6ujJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4 xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglVmDaxe69+IA irpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+Vr xYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs5Qiqp4b t1RxD0iScHLz85/3/Risxsl6JQvRatqwViz4LIfI2ZMfxzdb7fc9wHX2pMRsleVyJDDY28YY UBDPcPM/hEoIfyvFYOsQK+CBOwCO/z1jNFhHn71rA63eQ7FgHG2RQtEcgPsHvKttX1LrkdWv 2rwanP0DXDde9W2Tbj54jVbxsspumMXbNufsrL00kgCRnJgUmXqYz4JTOVyuUNvHaG7+d7Wu KvjnQoqwB1ojS12sgsjYzJi5sTx1vZ+yt5x4M1Kse5SE59edOlHoNQtyCAO4RoX8wiXmdlsz s5xL0eoZO3YjQGxZA9yxPca/GLaZWE7xPiWeqLPDt1hnJodbSijBio60eg0PfzVsys3VZKsC VFlt7Mu2gI1xPJ68iHTuJx/ka92TqSzgzT5PxILEI0mKbBJJ4hxbkwlpUXsUvdBCP5hEL2jK qOekUl/Oin9fjnb634qpOAM4J4kALzP6Q0lsCiAOk1MxICU3WZ9Om8zLHj+Ff2QLROjv04iK nZt5XaKNwDpq64HQBVyJwj5AilAzi619QYgGMHLE5EeB2ZkojkIF7OIPXiAve+h1Sgiitkx/ fDPrH5GJXCMmDDkKv9fbZ680NT1A0zzclG651IDrEBPen8V1TqtN3YCx85Kxa7z/zmCNV7zI MeWHiADrWXMKPI4he04bcEJPDET4sIsn6pIP88ovXqkHURmFkHfKDv04FBO16iGfEzG0SUe2 DhyvwGDH0WvwcjBLjyiVCYSzMVbHGvRb496ywTB4evDIOFTYeo1u/SlBynF4FbMzgVQmuHFm 3lIsDdA69VOXCiZ/R5mzlBboCPDooo1BWgrgj/kuM1Ie/d+ylevpXmhoEsur/j0Coq/DkxNP yzlmGAS2YuwDENTj4ymaFj+Alzkwjel6d/hPNcGJpY4PYbCl5mZ66Z9PRzDpXJYiyEZs2AEQ /0TdCvADV3RdU0kYcD
You must declare enough morphisms so that you can rewrite under "T",
and also under "cons". In this case you need a relation on lists to be
able to do that.
The solution below 1) defines a relation eqvl on lists, 2) declares
cons as a morphis 3) declares T as amorphism. I think the proofs left
admitted should be straightforward.
-------------------------------8X------------------------
Require Export List.
Export ListNotations.
Require Export Setoid.
Require Export SetoidClass.
Require Export Morphisms.
Inductive FunSym : Type := A | M.
Inductive term: Type :=
| V : nat -> term
| T : FunSym -> list term -> term .
Inductive eqv : term -> term -> Prop :=
(* some equations ...*)
| eqv_ref: forall x, eqv x x
| eqv_sym: forall x y, eqv x y -> eqv y x
| eqv_trans: forall x y z, eqv x y -> eqv y z -> eqv x z
| A_compat : forall x x' ,
eqv x x' -> forall y y' ,
eqv y y' -> eqv (T A [x ; y] ) (T A [x' ; y']).
Hint Constructors eqv.
Inductive eqvl : list term -> list term -> Prop :=
eqvl1: eqvl nil nil
| eqqvl2: forall x x' l l', eqv x x' -> eqvl l l' -> eqvl (x::l) (x'::l').
Hint Constructors eqvl.
Add Parametric Relation : term eqv
reflexivity proved by @eqv_ref
symmetry proved by @eqv_sym
transitivity proved by @eqv_trans
as eqv_rel.
Lemma eqvl_ref: reflexive _ eqvl.
Admitted.
Lemma eqvl_sym: symmetric _ eqvl.
Admitted.
Lemma eqvl_trans: transitive _ eqvl.
Admitted.
Add Parametric Relation : (list term) eqvl
reflexivity proved by @eqvl_ref
symmetry proved by @eqvl_sym
transitivity proved by @eqvl_trans
as eqvl_rel.
Add Parametric Morphism : T with
signature eq ==> eqvl ==> eqv as T_mor.
Admitted.
Add Parametric Morphism : cons with
signature eqv ==> eqvl ==> eqvl as cons_mor.
Admitted.
(* MY QUESTION: how to add some parametric morphism so that rewrites
like the following succeed? *)
Lemma not_ok : forall x x' y,
eqv x x' ->
eqv (T A [x;y]) (T A [x'; y]).
Proof.
intros x x' y H.
rewrite H.
Abort.
Le dim. 17 mars 2019 à 19:41, Dan Dougherty
<dougherty.dan AT gmail.com>
a écrit :
> I should have said more in my original post. I have tried
> (essentially) what Pierre suggested, and several other things that
> ought to work in the sense that they made sense semantically. And
> having proved various compatibility lemmas, I can _apply_ them and get
> the results I need. But when I want to declare a parametric morphism
> and _rewrite_ then I get the infamous setoid rewrite error.
> My impression that my problem is to find a way to fit a natural
> compatibility result and ensuing morphism declaration into a format
> that generalized rewriting will accept.
> thanks in advance for any help.
> Dan
> On Fri, Mar 15, 2019 at 5:10 AM Pierre Courtieu
> wrote:
> > I guess you need to define a relation for the list of terms. Something
> > like:
> > C1: eqv x x’ -> like x::l == x’::l
> > C2:l ==l’ -> x::l ==x::l’
> > Ctrans: ...
> > P
> > Le ven. 15 mars 2019 à 07:59, Dan Dougherty
> > a écrit :
> >> (* Hi all,
> >> I'm having trouble setting up a generalized (setoid) rewriting
> >> mechanism. A simplified version of my setting is as follows.
> >> I'm working with first order terms and an inductive relation defining
> >> provable equality based on some axioms, and I want to be able to
> >> rewrite modulo that relation. All is straightforward if I define
> >> terms using the function symbols as constructors (see the second
> >> snippet) but I'd prefer to define terms more generally using the first
> >> "term" definition below.
> >> My question is, how can I define a parametric morphism, analogous to
> >> what is done for A' and Lemma ok in the latter snippet, that allows
> >> rewriting to succeed in Lemma not_ok?
> >> thanks in advance,
> >> Dan
> >> | V : nat -> term
> >> as eqv_rel.
> >> eqv x x' ->
> >> Proof.
> >> intros x x' y H.
> >> try rewrite H.
> >> Abort.
> >> (* ********* below works fine ****************** *)
> >> Inductive term' : Type :=
> >> | V' : nat -> term'
> >> | A' : term' -> term' -> term' .
> >> Inductive eqv' : term' -> term' -> Prop :=
> >> | eqv'_ref: forall x, eqv' x x
> >> | eqv'_sym: forall x y, eqv' x y -> eqv' y x
> >> | eqv'_trans: forall x y z, eqv' x y -> eqv' y z -> eqv' x z
> >> | A'_compat : forall x x' ,
> >> eqv' x x' -> forall y y' ,
> >> eqv' y y' -> eqv' (A' x y) (A' x' y').
> >> Hint Constructors eqv'.
> >> Add Parametric Relation : term' eqv'
> >> reflexivity proved by @eqv'_ref
> >> symmetry proved by @eqv'_sym
> >> transitivity proved by @eqv'_trans
> >> as eqv'_rel.
> >> Add Parametric Morphism : A' with
> >> signature eqv' ==> eqv' ==> eqv' as A'_mor.
> >> exact A'_compat.
> >> Qed.
> >> Lemma ok : forall x x' y,
> >> eqv' x x' ->
> >> eqv' (A' x y) (A' x' y).
> >> Proof.
> >> intros x x' y H.
> >> now rewrite H.
> >> Qed.
> >> Dan Dougherty
> >> 231 Fuller Labs
> >> Worcester Polytechnic Institute
> >> WPI Department of Computer Science:
> >> http://web.cs.wpi.edu/~dd/
> >> Ombuds:
> >> http://www.wpi.edu/offices/ombuds/
> Dan Dougherty
> 231 Fuller Labs
> Ombuds:
