Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop
- From: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
- To: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop
- Date: Fri, 22 Mar 2019 23:37:25 +0000
- Accept-language: en-CA, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fdhzs2010 AT hotmail.com; spf=Pass smtp.mailfrom=fdhzs2010 AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM05-CO1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:Qr5ksR07H6+RAdKxsmDT+DRfVm0co7zxezQtwd8ZsesWKfXxwZ3uMQTl6Ol3ixeRBMOHsqoC1LCd6/6ocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbAhEmSaxbalwIRmoogndqsgbipZ+J6gszRfEvmFGcPlMy2NyIlKTkRf85sOu85Nm7i9dpfEv+dNeXKvjZ6g3QqBWAzogM2Au+c3krgLDQheV5nsdSWoZjBxFCBXY4R7gX5fxtiz6tvdh2CSfIMb7Q6w4VSik4qx2UxLjljsJOCAl/2HWksxwjbxUoBS9pxxk3oXYZJiZOOdicq/BeN8XQ21OUNtMVyxaGoOzcZcAD/YPM+ZfqonyvVoOrR2jDgWoC+7izjpEi3nr1qM4zushCxnL0gw+EdwTrHTaotb7NKkQXu+pw6bF1i/MY+9K1Trn9ITEbg0trPeRVrxwa8rRzkwvGhvBgFqKsozlODWV3fkUv2eY7+pgUuSvi2E6oA9sojig2MEsiobQiokIyF7E6DhyzYE7JdKlSE56YMWkHIVMuy2HK4d7WcMiQ2Z0uCY/0LIGuJq7cDIWx5Qgwh7ScvqKeJWG7BLkUeaeOzZ4hHR9dbKknxay60mgyuvzVsaqylZGtDZKkt7JtnwV2BzT69SHSvtg/ki6wzqP1gfT5+dZKk43jarWM5EszqIqmpcXr0jPBDL6lUvsgKKVdUgo4uao5Prkb7n6o5KRMpF7hh36P6ksn8GyAPk0PwYMUmWe+umwyr/u8lD8TbhJkPE6j6fZvZbHLsoBvKG5GRVa0oM75ha/ETim1NMYkGEfIl9ZfxyLk4jkN0jQLf7hEPuzmlOsnyx1yPzcOb3hH4nNIWPEkLf8e7Zy9lRQyBIpzdBY+5JbFK0OIO7yWk/2stzUFBg5MxGow+bjD9V90YAeVXiTDa+eNaPeqV6I5uQxLOmQfIIYtyrxJ+Ih6vLwl3M1hFEQcbOq0JYUcHy4G+5pI0SdYXrimNcBFmIKsxIwTOP3iF2DUCVTa2iuU64h+j02E4KmDYDfRoComrOB3SO7EodKaWBBD1CACW3oeJmcW/cQdCKSJddsnSADVbi4UoMuyRWutBLhxLd8NerV+igYtYr529Rv5u3Tkwsy9T1uAMiH3WGNVTI8omRdaDa1wKl5lmN8zl2Oy7Qw1/NRGMBa4bVGUwMwOITA5/d5GsvxWwfEc83PTlu6FJHuSzo2V5c6x8IES0d7AdSryB7ZlWL+CLgM0rePGZYc86TG3nG3KdwrmFjc06x0rVA9Rc0HcF+mgahwvzPTCojG1g25iu7+e6gczjWXrD7b5WqJoERRUQo2WqLACyNMLnDKpMj0sxuRB4SlDq4qZ04ckJfTeJsPUcXgiBB9fNmmPd3fZ2yrnGLpXkSIwa+JZYvuPW4a2XeEURRWo0Uo5X+DcDMGKGK5uWuHV25uEk7qakLot+J5rSHjFxJm/0Sxd0RkkoGN1FsViPibF6xB+Jsh4HpkgBItWVG30pTRFsaKoBdncONEe9Qh7Vxb1GXf8QtgIpinKKMkjVkbIV16
To be retrospective, I indeed want to put all definitions into Type. However, there are external dependencies / historical development.
For example, I depend on a library which puts things into Prop, so if I don't operate in Prop, I will not be able to eliminate from definitions from this library. This library, in turn, depends on some definitions from stdlib, which are also defined in Prop.
I am not sure if stdlib2 plans to make things primarily in Type and make use of sProp whenever necessary. If that's the case, it would make the future much brighter.
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
Sent: March 22, 2019 7:09 PM
To: coq-club AT inria.fr
Why do you want your inductive to be in Prop? Is there a problem with
putting it in Set or Type?
Gaëtan Gilbert
On 22/03/2019 23:50, Jason -Zhong Sheng- Hu wrote:
> Hi,
> thanks again for all your help. I want to follow up on this question.
> Experimenting around, I found that most of the methods work only for
> those inductive types in which no recursive case live in closure (what's
> the terminology for this? it's free algebras generated by poly functors
> with at most 1st order). for example, following kind of definitions
> wouldn't work well:
> Inductive T : Prop := ... | ctor : (forall x, P x -> T) -> T | ...
> This kind of definitions appears, for example, in locally nameless
> representation [*]. Consider the case for subtyping between universal
> types in F<: (imagine the constructor to be `tabs` and a type opening
> operation `open`),
> case_tabs : forall L G S1 S2 U1 U2,
> G |- S2 <: S1 ->
> (forall x, x \notin L -> (x , S2) :: G |- open x U1
> <: open x U2) ->
> G |- tabs S1 U1 <: tabs S2 U2
> Notice that the body case lives in a closure. Therefore, the size of the
> derivation tree cannot be measured by natural numbers.
> I was exploring a more general counter. Consider following definition.
> Inductive card : Type :=
> | base : card
> | rec1 : card -> card
> | rec2 : card -> card -> card
> | clsr : forall L, card -> (forall x, x `notin` L -> card) -> card.
> The intention of this definition is to form a simulation of Prop's
> containing recursive cases in closures. However, it turns out that I
> cannot prove this simulation exists, even with Fabian's trick. To
> understand the blocker, consider a modified version of case_tabs:
> case_tabs' : forall L G S1 S2 U1 U2 c1 c2,
> [ c1 ] G |- S2 <: S1 ->
> (forall x (ni : x \notin L), [ c2 x ni ] (x , S2) ::
> G |- open x U1 <: open x U2) ->
> [ clsr c1 c2 ] G |- tabs S1 U1 <: tabs S2 U2
> where card is contained in the square brackets preceding the judgment.
> when mapping from case_tabs to case_tabs', the inductive hypothesis becomes
> forall x, x \notin L -> exists c, [ c ] (x , S2) :: G |- open x U1 <:
> open x U2
> and I need to constructor a c2, which lives in Type. this cannot be
> proved because ex cannot be eliminated into Type. On the other hand,
> card needs to be defined in Type because it serves as size.
> I hope this problem makes sense. I once a while find Prop in Coq is so
> hard to work with and cumbersome to have. I am wondering if there is a
> way out?
> *Thanks,*
> *Jason Hu*
> *https://hustmphrrr.github.io/*
> [*] https://link.springer.com/article/10.1007/s10817-011-9225-2
> *From:* Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
> *Sent:* February 4, 2019 9:36 AM
> *To:* Fabian Kunze; coq-club AT inria.fr
> *Subject:* Re: [Coq-Club] well-founded induction on the size of the
> great, thx you all. I will try out these approaches.
> *Sincerely Yours,
> Jason Hu*
> *From:* coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf
> of Fabian Kunze <kunze AT ps.uni-saarland.de>
> *Sent:* February 2, 2019 5:14 PM
> *To:* coq-club AT inria.fr
> Hello Jason,
> One way to do this would be to add another parameter to your inductive
> predicate to track the 'size' of the tree. Then induction on this
> parameter works. (An example is the derivation of vectors of length n
> from list that adds the length as an explicit parameter.)
> If you don't want to change your definition, you can copy it with this
> parameter and show equivalence of the two inductive types ( P x <->
> exists n, P' n x).
> Best,
> Fabian
> On Sat, 2 Feb 2019, 22:54 Jason -Zhong Sheng- Hu, <fdhzs2010 AT hotmail.com
> <mailto:fdhzs2010 AT hotmail.com>> wrote:
> Hi,
> Conceptually, when proving one inductively defined Prop from another
> can be considered as a translation between derivation trees.
> However, I am recently running into a problem that, when taking this
> view, such translation does not have to be structural. In
> particular, sometimes generated inductive hypothesis by `induction`
> doesn't make immediately sense, but can be applied to some other
> derivation trees after certain processing, so that some measure can
> also be applied to argue termination.
> The tricky part here is Prop -> nat is not meaningfully definable
> type, because Prop cannot be eliminated in Type/Set, so even if I
> know how to define measures on paper, I am not able to define one in
> Coq.
> Is there any way out so that well-founded induction can be done
> intuitively?
> *Sincerely Yours,
> Jason Hu*
Gaëtan Gilbert
> Hi,
> wouldn't work well:
> operation `open`),
> G |- S2 <: S1 ->
> <: open x U2) ->
> | base : card
> | rec1 : card -> card
> open x U2
> way out?
> *Thanks,*
> *Jason Hu*
> *Sincerely Yours,
> Jason Hu*
> Hello Jason,
> exists n, P' n x).
> Best,
> Fabian
> Hi,
> Coq.
> intuitively?
> *Sincerely Yours,
> Jason Hu*
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Jason -Zhong Sheng- Hu, 03/22/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Gaëtan Gilbert, 03/23/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Jason -Zhong Sheng- Hu, 03/23/2019
- Re: [Coq-Club] well-founded induction on the size of the derivation tree of Prop, Dominique Larchey-Wendling, 03/23/2019
