coq-club - Re: [Coq-Club] Use a map in an inductive type
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Use a map in an inductive type
  • Date: Wed, 10 Apr 2019 14:03:44 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-1.u-ga.fr
Hello Nicolas,
The error is induced by the "NoDup" field of M.t.
One workaround could be to split the inductive definition in two parts:
Inductive raw_tree: Type :=
mkRawTree: T -> M.Raw.t raw_tree -> raw_tree.
Import M.
Inductive wf_tree: raw_tree -> Prop :=
mkRawTree_wf (x:T) (l: M.t raw_tree):
(forall p, List.In p l.(this) -> wf_tree (snd p))
-> wf_tree (mkRawTree x l.(this)).
Record tree : Type := { raw: raw_tree; wf: wf_tree raw }.
But, I do not know if such an approach works well in practice...
S.
Le 10/04/2019 à 11:23, Nicolas Osborne a écrit :
Dear Coq-Club,
I need to define a rose tree with a map instead of a list. As I don’t have any reason to care about efficiency in this context, I use FMapWeakList from the Standard Library and declare the following:
Require Import Coq.Structures.DecidableTypeEx.
Require Import Coq.FSets.FMapWeakList.
Variable T:Type.
Module M := FMapWeakList.Make(Nat_as_DT).
Inductive tree: Type := mkTree: T -> M.t tree -> tree.
Then, Coq greets me with the following error message:
      Error: Non strictly positive occurrence of "tree" in "nat -> M.t tree -> tree".
As I understand it, this means that "tree" occurs at the left of an arrow in one of the argument of the constructor (namely "M.t tree"), which is forbidden for consistency reasons.
Is there any way around ?
My first guess would be to use a list of products in the tree:
Inductive tree’: Type := mkTree’: T -> list (nat * tree’) -> tree’.
and then make sure that this list behaves like a map when writing the functions handling the modifications of the tree.
But if there is a way to use directly a map in the tree, that would be a relief.
Thanks,
Nicolas Osborne
