coq-club - Re: [Coq-Club] Coqtop links broken
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coqtop links broken
  • Date: Tue, 7 May 2019 18:08:09 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua1-f46.google.com
  • Ironport-phdr: 9a23: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
Hi,
Feel free to open an issue about this lack of documentation at
https://github.com/coq/coq/issues.
If you see how to fix the doc, you may also open a pull request directly.
Thanks,
Théo
Le mar. 7 mai 2019 à 17:56, Robert Rand
<rrand AT seas.upenn.edu>
a écrit :
> For anyone else running into this problem, there is a -Q option that can be
> passed to coqdoc (corresponding to the -Q option in coqc): This is shown if
> you run Coqdoc --help but it isn't in Coq's online documentation.
> On Mon, May 6, 2019 at 4:06 PM Robert Rand
> wrote:
>> Hi,
>> I'm trying to compile coq to HTML using coqdoc but all the links in the
>> index are broken. To be precise, they all go to
>> VQC.[name].html#[lemma_name] (where VQC is the library name given in the
>> _CoqProject) which doesn't exist. [name].html#[lemma_name] exists, but it
>> doesn't take me to the right place in the file.
>> The command I'm using is
>> coqdoc -html --utf8 --coqlib http://coq.inria.fr/library/ --parse-comments
>> --index coqindex --toc --toc-depth 2 --lib-name "" --lib-subtitles *.v
>> though I've tried a variety of flags.
>> Any idea how to fix this?
>> Thanks,
>> Robert
