coq-club - Re: [Coq-Club] FMap with abstract data type
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] FMap with abstract data type
  • Date: Fri, 24 May 2019 14:23:30 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vzaliva AT cmu.edu; spf=Pass smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-io1-f52.google.com
  • Ironport-phdr: 9a23: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
Jasper,
This is where I started, but using `Ae` as a equality for values it is impossible to prove the following:
Instance MapsTo_A_proper: Proper ((eq) ==> (Map.Equiv Ae) ==> (Ae) ==> iff) (NM.MapsTo).
It boils down to:
Ae x y →
Map.Equiv Ae m0 m1 →
Map.MapsTo k x m0 ↔ Map.MapsTo k y m1
(unless I am missing something)
Vadim
Vadim Zaliva A button for name playback in email signature
CMU ECE Ph.D. candidate
Mobile/Signal/WhatsApp: +1(510)220-1060
On Fri, May 24, 2019 at 2:06 PM Jasper Hugunin <jasperh AT cs.washington.edu> wrote:
You can use
From Coq Require OrderedTypeEx FMapAVL FMapFacts.
Module Map := FMapAVL.Make OrderedTypeEx.Nat_as_OT.
Check Map.t : Type -> Type. (* The values can be anything you like *)
Check Map.Equiv : forall X, (X -> X -> Prop) -> (Map.t X -> Map.t X -> Prop).
(* You get a relation Map.Equiv for any relation between elements. Proving it is a congruence relation shouldn't be hard, but I'm not sure is in the standard library. *)
(* If the equality on values is Init.Logic.eq, i.e. a1 = a2, then you can instead use Map.Equal, which does have Proper instances proven in MapProperties. *)
Module MapProperties := FMapFacts.Properties Map.
(* Also MapProperties.F has useful stuff. *)
(* This can be used as *)
Axiom A : Type.
Check Map.t A. (* This is the type of maps with keys in nat and values in A. *)
- Jasper Hugunin
On Fri, May 24, 2019 at 11:51 AM Vadim Zaliva <vzaliva AT cmu.edu> wrote:
I am trying to figure out how to use FMap with abstract data type and
equality. I need a map where the keys are natural numbers, but values belong to an abstract type A. I can assume that this type has an equality Ae which is decidable, and a strict ordering.
I will need to have an Equiv relation between two maps (backed up by
Ae for elements). Finally, I would like to be able to prove Proper
instances for basic operations, like:
  Proper ((eq) ==> (equiv) ==> (equiv) ==> iff) (NM.MapsTo).
Instance find_A_proper:
  Proper ((eq) ==> (equiv) ==> (equiv)) (NM.find (elt:=A)).
It looks like the map needs to be abstracted over A using a module.
This post http://www.newartisans.com/2016/10/using-fmap-in-coq/ gives
some good intro but stop shorts from abstracting values. It also looks
like I will need to use Sord functor from FMapInterface. I feel
like all pieces are there but having difficulty putting it all
together. I have not been able to find any relevant examples. Could
somebody please point me in the right direction? Thanks!
