- To: Colin Stebbins Gordon <colin.s.gordon AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Guardedness check sensitive to use of section variables?
- Date: Mon, 10 Jun 2019 21:19:52 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt1-f169.google.com
- Ironport-phdr: 9a23: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
Hi Colin,
Although a surprising quirk of nested Cofixpoints, this is actually the expected behavior.
Quoting CPDT (http://adam.chlipala.net/cpdt/html/Cpdt.Coinductive.html)
> a co-recursive call must be a direct argument to a constructor, nested only inside of other constructor calls or fun or match expressions.
To "fun" and "match", add "cofix" (but not "fix"!).
"smap" and "smap2" normalize respectively to terms of the forms:
smap = (fun A B f => (cofix s := ...))
smap2 = (fun A B => (cofix f s := ...))
Notably, they are not convertible to each other. The arity of each cofix is fixed once and for all.
Now unfolding "smap" and "smap2" in the definitions of "incr" and "incr2", and beta-reducing...
> CoFixpoint incr (w : wtree) : wtree :=
> match w with
> | node n ls => node (S n) (Cons w ((cofix smap_f s := ... incr ...) ls))
> end.
> (* The following is *rejected* by the guardedness checker, using smap2
> defined with an argument *)
> CoFixpoint incr2 (w : wtree) : wtree :=
> match w with
> | node n ls => node (S n) (Cons w ((cofix smap2 f s := ... f ...) incr2 ls))
> end.
Crucially, since "f" is a "fun" parameter of "smap", beta-reduction substitutes it with "incr", whereas "f" is a "cofix" parameter of "smap2", so "incr2" remains stuck outside.
Now looking at the guardedness condition, "incr" is fine: its recursive occurence is nested, successively, in a "match", a "node" (that's at least 1 constructor), a "Cons", a "cofix", and another "Cons".
"incr2" however, is nested not *inside* the "cofix", but in one of its arguments, which is entirely a different location.
The definition is not guarded according Coq's rules of guardedness. I don't have a formal reference to point to, but at least for "match" and "cofix" the right shapes can be illustrated more precisely as follows:
match BAD with
| p => GOOD
end BAD
(cofix f x ... z := GOOD) BAD
There definitely exist alternative guardedness conditions that would accept more productive programs, but as those illustrate, the current one has the overwhelming advantage of simplicity.
Regards,
Li-yao
On 6/10/19 8:36 PM, Colin Stebbins Gordon wrote:
I've been working with a structure that is essentially a coinductive data
type that contains a coinductive collection of itself. While defining
cofixpoints on this structure, I kept bumping into a weird behavior where a
seemingly sensible productive definition would be rejected for my chosen
coinductive collection, but accepted for the streams in the standard
library. Eventually I tracked it down to how the notion of map is
declared: of two seemingly equivalent ways of defining things, one passes
the guardedness check, and the other is rejected.
Here's a self-contained definition of (possibly-finite) streams, along with
two definitions of map:
Set Implicit Arguments.
Section Streams.
Variable A : Type.
CoInductive Stream : Type :=
Cons : A -> Stream -> Stream
| Nil : Stream.
End Streams.
Section Map.
Polymorphic Variables A B : Type.
Polymorphic Variable f : A -> B.
Polymorphic CoFixpoint smap (s:Stream A) : Stream B :=
match s with
| Nil _ => Nil _
| Cons x xs => Cons (f x) (smap xs)
end.
End Map.
Section Map2.
(*Polymorphic Variable f : A -> B.*)
(* Notice that now instead of making f a variable, it is not an argument to
smap(2) *)
Polymorphic CoFixpoint smap2 (f : A -> B) (s:Stream A) : Stream B :=
match s with
| Nil _ => Nil _
| Cons x xs => Cons (f x) (smap2 f xs)
end.
End Map2.
Unset Implicit Arguments.
The only difference between smap and smap2 is that one is defined with f as
a section variable, while the other takes it as a parameter.
Now if I define a simplification of what I was working with:
(* A simple coinductive structure with (1) data and (2) a container of
itself *)
CoInductive wtree : Set :=
| node : nat -> Stream wtree -> wtree.
I can try to define two versions of the same cofixpoint, one accepted and
one rejected:
(* The following is accepted by the guardedness checker, using smap defined
with a Variable *)
match w with
| node n ls => node (S n) (Cons w (smap incr ls))
end.
match w with
| node n ls => node (S n) (Cons w (smap2 incr2 ls))
end.
The error message I get for incr2 is:
Recursive definition of incr2 is ill-formed.
In environment
incr2 : wtree -> wtree
w : wtree
n : nat
ls : Stream wtree
Unguarded recursive call in
"cofix smap2 (f : wtree -> wtree) (s : Stream wtree) : Stream wtree :=
match s with
| Nil _ => Nil wtree
end".
Recursive definition is: "fun w : wtree => match w with
w (smap2 incr2 ls))
end".
The only difference is the use of the section variable when defining the
map. I realize syntactic guardedness checks are brittle by nature, but
this still surprised me: I would not expect this particular change to
affect the guardedness check. Is this by design, a quirk of the current
implementation (this is 8.9.0), or is there a subtle reason I'm missing
that one (or both?) should actually be rejected?
Thanks,
Colin
- [Coq-Club] Guardedness check sensitive to use of section variables?, Colin Stebbins Gordon, 06/11/2019
- Re: [Coq-Club] Guardedness check sensitive to use of section variables?, Li-yao Xia, 06/11/2019
