coq-club - Re: [Coq-Club] Line numbers in list printing?
  • To: coq-club AT inria.fr
  • Cc: Samuel Gruetter <gruetter AT mit.edu>
  • Subject: Re: [Coq-Club] Line numbers in list printing?
  • Date: Sun, 23 Jun 2019 02:14:13 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jrg358 AT cornell.edu; spf=Pass smtp.mailfrom=jrg358 AT cornell.edu; spf=None smtp.helo=postmaster AT mail-io1-f48.google.com
  • Ironport-phdr: 9a23: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
I was not aware of the ability to insert newlines in format clauses; I similarly have a notation for every statement in my language, so I ended up doing something very similar to what Samuel did in bedrock2. Thanks so much!
Josh
On Fri, Jun 21, 2019 at 1:20 PM Ralf Jung <jung AT mpi-sws.org> wrote:
Hi,
On 21.06.19 18:52, Samuel Gruetter wrote:
> I'd like to have the same in bedrock2! I didn't try anything zip-with-index
> related yet, but we have a notation for separation logic equivalences, which
> prints (P1 * P2 * ... Pn <==> Q1 * Q2 * ... * Qn) as
> [P1; P2; ... Pn]
> === seps iff ===
> [Q1; Q2; ... Qn]
> https://github.com/mit-plv/bedrock2/blob/ce3f6ee55351d89e0c5091a4e5af98b3ae778dae/bedrock2/src/Map/SeparationLogic.v#L218
> which is probably similar to what you already have.
> Another ingredient you'd need would be to print each element of a list on a new
> line. I haven't managed to do this within a notation for lists, but instead I
> had to insert a newline for each possible element of the list, see here:
> https://github.com/mit-plv/riscv-coq/blob/ab9adb6ce5c104886a3a435d16b0cd78c7d1a64f/src/Utility/InstructionNotations.v
We are doing something like "one element of a list per line" in the Iris /
Separation Logic Proof Mode, you can find the Notation for that at
<https://gitlab.mpi-sws.org/iris/iris/blob/472aa3bcb129182fd6fc9aca241a38340c9ceafd/theories/proofmode/notation.v>.
Basically, you can add the newline to the notation for "cons".
We don't have line numbers, though.
Kind regards,
Ralf
> Please let us know if you make progress on this :)
> On Sat, 2019-06-15 at 15:28 -0400, Joshua Gancher wrote:
>> Hi all,
>> I am mechanizing a program logic, and have an equivalence judgement (written
>> as an Inductive) of the form Equiv xs xs', where xs and xs' are of the type
>> list Cmd.
>> My current way of displaying this goal looks something like [:: p1; p2; p3;
>> p4] <~~> [:: p5; p6; p7] (using ssreflect's notation for lists.) I would like
>> to instead display something like:
>> 0 : p1;
>> 1 : p2;
>> 2 : p3;
>> 4 : p4
>> 0 : p5;
>> 1 : p6;
>> 2 : p7.
>> Is there a simple programmatic way of doing this, akin to defining a
>> pprint_equiv : forall xs xs', Equiv xs xs' -> string? I think I could also
>> achieve this by zipping each list with an increasing sequence of nats, and
>> doing something special with this list of pairs, but this seems overkill if
>> there is a more natural solution.
>> Thanks,
>> Joshua
Website: https://people.mpi-sws.org/~jung/
