- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] CoqIDE failure on Windows
- Date: Sun, 23 Jun 2019 18:12:49 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga06.intel.com
- Dlp-product: dlpe-windows
- Dlp-reaction: no-action
- Dlp-version: 11.0.600.7
- Ironport-phdr: 9a23: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
Dear Cao,
as Jim suggests the most likely cause are corrupted configuration files in your user folder. Would you mind sending me the files from any machine on which CoqIDE does not start, so that we can debug and fix the problem and also think about what might be the root cause for the corruption. Alternatively create an issue on Github and attach the files.
Also it would be interesting to know if you use any cloud sync mechanism on the machines showing the issue (this could corrupt the files).
In case deleting user local config files does not help, Microsoft/SysInternals ProcMon might help you to see what is going on.
Best regards,
Michael
Hi Cao,
I've had a similar problem in the past. CoqIDE creates two configuration files in C:\Users\<USERNAME>\AppData\Local\coq. If they are corrupted CoqIDE may not start. I suggest renaming or removing the existing files and reinstalling CoqIDE.
Hope this helps,
Jim
On Sat, Jun 22, 2019 at 11:53 PM Cao Qinxiang <caoqinxiang AT gmail.com> wrote:
Intel Deutschland GmbH |
- [Coq-Club] CoqIDE failure on Windows, Cao Qinxiang, 06/23/2019
- Re: [Coq-Club] CoqIDE failure on Windows, Jim Fehrle, 06/23/2019
- RE: [Coq-Club] CoqIDE failure on Windows, Soegtrop, Michael, 06/23/2019
- RE: [Coq-Club] CoqIDE failure on Windows, Soegtrop, Michael, 06/24/2019
