coq-club - Re: [Coq-Club] rewriting something used in a subsequent hypothesis
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] rewriting something used in a subsequent hypothesis
  • Date: Fri, 12 Jul 2019 16:07:00 +0200
  • Organization: LORIA
Hi Jeremy,
You cannot rewrite in hypotheses on which other hypotheses depend.
You have to rewrite simultaneously in them.
You can try
revert H0 H2; rewrite <rew. eq>; intros H0 H2
If you can use subst, it generally does not suffer
from that problem.
Best,
Dominique
Le 12/07/2019 à 16:02, Jeremy Dawson a écrit :
> Hi,
> I have the following goal:
> (earlier hyps, then)
> H0 : (Γ1 ++ Γ2) ++ ?W ⊦ A :: Δ
> H2 : Gnh_height H0 < n
> H : (Γ1 ++ B :: Γ2) ++ ?W0 ⊦ Δ
> H1 : Gnh_height H < n
> To make use of these hypotheses I need them in the form
> H0 : Γ1 ++ Γ2 ++ ?W ⊦ A :: Δ
> H : Γ1 ++ B :: Γ2 ++ ?W0 ⊦ Δ
> trying to rewrite with app_assoc_reverse produces the errors
> Error: Cannot change H0, it is used in hypothesis H2.
> Error: Cannot change H, it is used in hypothesis H1.
> Is there any reason why what I'm trying to do should be invalid?
> How can I get around this problem?
> Thanks for any help
> Jeremy
