coq-club - Re: [Coq-Club] Rewriting in sort Type
  • From: Vincent Semeria <vincent.semeria AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewriting in sort Type
  • Date: Fri, 9 Aug 2019 16:50:20 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vincent.semeria AT gmail.com; spf=Pass smtp.mailfrom=vincent.semeria AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot1-f42.google.com
  • Ironport-phdr: 9a23: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
That's perfect, thanks.
On Fri, Aug 9, 2019 at 4:13 PM Christian Doczkal <christian.doczkal AT ens-lyon.fr> wrote:
Note that, due to cumulativity, Xeq *is* already a crelation. So the following works for me:
Require Import Setoid CRelationClasses CMorphisms.
Section X.
Variables (X : Type) (Xeq : X -> X -> Prop) (Xlt : X -> X -> Type).
Instance Xeq_equiv : CRelationClasses.Equivalence Xeq. Admitted.
Instance Xlt_morph : CMorphisms.Proper (Xeq==>Xeq==>iffT) Xlt. Admitted.
Goal forall x y z: X, Xeq x y -> Xlt x z -> Xlt y z.
Proof. intros x y z E L. rewrite <- E. exact L. Qed.
End X.
Best,
Christian
On 8/9/19 1:20 PM, Vincent Semeria wrote:
> Indeed, I managed to do a rewriting in Type using CMorphisms directly.
> However, Xeq is a relation in Prop and when I try to mix
> Instance Xeq_equiv : RelationClasses.Equivalence Xeq.
> then the rewrite fails again with this error
> Tactic failure: setoid rewrite failed: Unable to satisfy the following constraints:
> UNDEFINED EVARS:
>  ?X34==[x y z H H0 |- crelation X] (internal placeholder) {?c}
> so it wants a crelation in Type.
> I think it would be a pity to generalize Xeq in sort Type, is there a way to rewrite a CMorphism over a RelationClasses.Equivalence ?
> On Fri, Aug 9, 2019 at 12:12 PM Christian Doczkal <christian.doczkal AT ens-lyon.fr <mailto:christian.doczkal AT ens-lyon.fr>> wrote:
>     Hi,
>     I'm not sure about the Add Parametric Morphism command, but for rewriting it suffices to declare type class instances for Equivalence/PreOrder/etc. and the right instances of "Proper". These come in two variants:
>     RelationClasses and Morphisms deal with relations in Prop
>     CRelationClasses and CMorphisms deal with relations in Type
>     Just make sure you are importing the right libraries and things should work.
>     Hope this helps!
>     Best,
>     Christian
>     On 8/9/19 12:04 PM, Vincent Semeria wrote:
>     > Dear Coq clubbers,
>     > I currently work on some ordered setoids (X, Xeq, Xlt) and for performance reasons I'd like the order to be in sort Type :
>     > Xlt : X -> X -> Type.
>     > Then I can store some information in Xlt, to speed up later functions that take Xlt as arguments. For example this is what C-CoRN does for the real numbers.
>     > However the compatibility between order and equality won't compile in sort Type :
>     > Add Parametric Morphism : Xlt
>     >     with signature Xeq ==> Xeq ==> iff
>     >       as Xlt_morph.
>     > because iff wants a Prop. Even if I define
>     > Definition iffT (A B:Type) := prod (A -> B) (B -> A)
>     > then Add Parametric Morphism complains that it wants a relation Type, ie a Type -> Type -> Prop.
>     > The documentation only mentions relations in sort Prop,
>     > https://coq.inria.fr/refman/addendum/generalized-rewriting.html
>     > Is there a way to do this ?
>     > Thanks,
>     > Vincent
