- From: Valentin Robert <valentin.robert.42 AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Strict positivity description in CIC spec
- Date: Tue, 13 Aug 2019 10:54:25 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=valentin.robert.42 AT gmail.com; spf=Pass smtp.mailfrom=valentin.robert.42 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot1-f67.google.com
- Ironport-phdr: 9a23:CB6cnhK8PtpsAUVB6dmcpTZWNBhigK39O0sv0rFitYgeKfvxwZ3uMQTl6Ol3ixeRBMOHsqgC0rCI+Pm5BiQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTagf79+Ngi6oRvQu8UZnIduN6Q8wQbVr3VVfOhb2XlmLk+JkRbm4cew8p9j8yBOtP8k6sVNT6b0cbkmQLJBFDgpPHw768PttRnYUAuA/WAcXXkMkhpJGAfK8hf3VYrsvyTgt+p93C6aPdDqTb0xRD+v4btnRAPuhSwaMTMy7WPZhdFqjK9Drx2hqR5wzY7abo+WKfRwYL/ScMgASmZdRMtcTTBNDp++YoYJEuEPPfxYr474p1YWohSxHw2sC/3pyj9Uh3/227Ax3fgmEQ7dwgMgBc4Ou2nTodXrLqgSVf66zK/UzTXCafNawy396I/TfR8/u/GMQah8fMXPxUQ0GAPFi0+fqY3hPz+PyusNtG2b4vNmWOmyhWAnrARxrSKuxscqkoTJh4QVykrF9Spj2oo1K8e4RFZ6Yd6iDZRQqyGbN5NoTc84WW1ovSI6xqUJuZ66YCgKyIknyAXFZ/ObdIiI5xTuX/uSLzdgnH9pZq6zihKo/UWjyuDwTNe43EtWoiZfk9TBtHYA3AHJ5MedUPty5EKh1C6P1w/N7uFEJlg5la/BJJ4gxr48j50TsVjeEiPvlkX7ja2bel8r+uiv7OTnbbHmqYGGO4BojQH+N7wims25AesmLggDR3aX9fi42bH5/kD0QK9GguMrnqXFqpzXJMYWqra8AwBP04Yj7xi/Dy2h0NQdhXQHMkhKeBaZgIjvJ1HOIfb4Ae2lg1Srizhk2erGPqH7DpjCMHTOi7jhfbNn5E5dzAo/18xQ55VRCr0ZOvL8RlfxtMDEDh8+KwG73+HnCMxk2owCXWKPH7SWPbjJsV6I4+IvO/ODaJUUuDb7Mfgl5uThgWU3mV8HLuGV2s4cb2n9FfB7KW2YZ2Dti5EPCzQkpA07GdLjjFCETT9VL0y1Va8m+nlvFouiAIHfR4brmruL0T2nWMEMTm9DA1GIV3zvctPXCL83dCuOL5o5wXQ/Xr+7Rtp5jE38hErB07Nia9Hs1GgAr5u6jYp64uTSkVc58jkmV53AgVHIdHl9myYzfxFz3K17phYgmFKK0Kw9hOABUNINuLVGVQA1MZOaxOt/WYirC1DxO+yRQVPjee2IRDQ4T9Y/2dgLOh8vFNCrjxSF1C2vUeYY
Indeed from reading:
We can see a check that the inductive type outside the nesting must be covariant. Which is why this works for `List`, but would not work for some contravariant datatype (one that uses its parameter as an argument to a function, for instance).
You can also see additional restrictions (some specific to Coq) in the previous lines (for instance, the nested inductive type must only appear as a parameter of the nesting type, not as an index, and nested inductive-inductive definitions seem to be rejected).
Now that does not necessarily answer the question as far as CIC is concerned.
- Valentin
On Tue, 13 Aug 2019 at 10:38, William J. Bowman <wjb AT williamjbowman.com> wrote:
This is a understandable enough solution, and thanks for the pointer to CPDT;
I'll take a look.
Thanks!
William J. Bowman
On Wed, Aug 07, 2019 at 12:02:12PM -0400, Hans Jacob Fehrmann Rojas wrote:
> Hi William,
> I'm not an expert but a very sutil interpretation of the rules seems that
> the nested positive condition should be applied only considering the arity
> of the inductives without the parameters as if the `List (Rose A)` would be
> a new inductive.
> So for your example:
> Inductive Rose (A : Set) : Set :=
> | rose : (List (Rose A)) -> Rose A.
> Should check the positivity condition with respect to (assuming is a valid
> declaration)
> Inductive ListRose : Set :=
> | nil : ListRose
> | cons : Rose A -> ListRose -> ListRose.
> This is the argument in Certified Programming with Dependent Types (3.8
> Nested Inductive Types)
> Also, it seems that the check of the positive condition for an inductive
> definition is done in coq sources in checker/indtype.ml, specifically the
> function `check_positivity` and it seems that the parameters are not taking
> in consideration when checking the positivity condition, so the arguments
> of Chlipala seems right
> Hope these helps
> Best,
> Hans.
> On Tue, Aug 6, 2019 at 11:00 PM William J. Bowman <wjb AT williamjbowman.com>
> wrote:
> > I just finished implementing the CIC positivity checker as specified in
> > the Coq
> > docs, but the docs seem under specified about how the strict positivity
> > algorithm should work.
> > https://coq.inria.fr/doc/language/cic.html#positivity-condition
> > If I try to implement the rules as specified, I get stuck in an infinite
> > loop
> > when checking nested inductive types.
> > Consider rose trees:
> > Inductive List (A : Set) : Set :=
> > | nil : List A
> > | cons : A -> List A -> List A.
> > I must show `Rose` occurs strictly positively in `(List (Rose A))`, from
> > the
> > type of the constructor `rose`.
> > Loop:
> > To show that `Rose` occurs strictly positively in `List (Rose A)`,
> > since `List (Rose A)` is of the form `(I p_0 ... p_m u ...)` and `List` is
> > not
> > mutually inductive, we must show the nested positivity condition for each
> > constructor of `List` after instantiating the types of the constructors
> > with the
> > parameter `(Rose A)`.
> > There are two cases:
> > - nil : `(List (Rose A))` satisfies nested positivity w.r.t. `Rose`
> > trivially.
> > - cons : `Rose A -> List (Rose A) -> List (Rose A)`
> > To show this satisfies nested positivity w.r.t. `Rose`, we must show that
> > `Rose`
> > occurs strictly positively in `List (Rose A)`.
> > goto Loop
> > For now, I've "fixed" this by allowing myself to assume strict positivity
> > holds
> > for `List (Rose A)` while checking nested positivity.
> > This seems okay, in a vague, intuitive, "something something greatest
> > fixpoints?" kind of way, but I'd like to be a little more formal than that.
> > Does anyone know what's missing from the Coq docs or what reference I
> > should
> > look at?
> > I usually start from the Coq docs as they have the most readable and
> > complete
> > CIC spec in one place.
> > I tried reading the Coq kernel code but.. failed.
> > I also tried Paulin-Mohring's "Inductive Definitions in the system Coq
> > Rules and
> > Properties", but can't find anything about nested inductive types.
> > William J. Bowman
- [Coq-Club] Strict positivity description in CIC spec, William J. Bowman, 08/07/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, roux cody, 08/07/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, Hans Jacob Fehrmann Rojas, 08/07/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, William J. Bowman, 08/13/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, Valentin Robert, 08/13/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, Stefan Monnier, 08/26/2019
- Re: [Coq-Club] Strict positivity description in CIC spec, Gaëtan Gilbert, 08/26/2019
