- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] sigT and Prop
- Date: Mon, 23 Sep 2019 11:49:39 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay6-d.mail.gandi.net
- Ironport-phdr: 9a23:xymoWhTklxr5N9W9cNzrssx5Kdpsv+yvbD5Q0YIujvd0So/mwa6ybRyN2/xhgRfzUJnB7Loc0qyK6vumAzxLuMbJ8ChbNsAVDVld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbdgMutyu+95YDYbRlWizqhe7NyKwi9oRnMusUMjoZuN6g8xgHXrnZLdOha2GBlLk+Xkxrg+8u85pFu/zlOt/4768JMTaD2dLkkQLJFCzgrL3o779DxuxnZSguP6HocUmEInRdNHgPI8hL0UIrvvyXjruZy1zWUMsPwTbAvRDSt9LxrRwPyiCcGLDE27mfagdFtga1BoRKhoxt/w5PIYIyQKfFzcL/Rcc8cSGFcWclfSjFBApikb4QRE+UBIehWr474p1QUrBu+AxSnCOfgxzJMg3P727Ax3eY8HgHcxAEuAswAsHrUotv2OqkdX++6w6vUwjvMdP5WxTTw5ZLUfhw9r/yBX7R9etfRx0k1EAPFi02dp43/MDSJyuQCqW6b4PJhW+Kuj24osB9+oiKzxswxjYTJiZgaxU7Y9SpjxoY5P9K4SE9/YdG/DpRQrT2aOpBtQsMhQ2BooyU6yrwDuZ6+YicK0o4rxxjBZPybaoWF5A/oWuiWITd9nn1lebS/ig698Uih1u38VtS0301QoipEldnBsG0G2R/L6sWfVPdx40Ws1SyN2gzP8O1IPEM5mKTBJ5I8xrM9lYIfvEvCEyPshUn7iKGbel8r9+Sy9ujqYanqq5mBPIFukA7+KL4hmsmnDOQ4LAcOW2+b9Pym1LL9+U32WrVLg/wvnqbEqpzaIN4Upq+9AwNP3YYs8RC/ACqn0NgCm3kIMk5FdAqGj4jvJV7OPOj1Aemij1muijtmxezKMqf8DpjOIHXPiqrtcLJ+5kJEzQo819Ff55ZaCrEbJ/LzX1f8tNPCARAnLwy72eDnBM9y1oMfXWKAGbGWMLnOsVKT/eIvIOmNZJQWuDb8Lvgl4uDhjWUjlV8bY6apwYMbaGqkEfR+P0WZfX3sj88dHmcNpwoyVfDliFmfUTFIfHuyRKI95jQjCI28F4vDR4atgKaA3CihBJFWaHpGWRiwFiLjcJzBUPMRYgqTJNVgm3oKT+uPUYgkgD6nNxPzzY1IL+7e9zcE/cbs3dVp7uuVmhA2/zFuE+yG0HCWTGBxm24SATk7wPYs8gRG1l6f3P0g0LRjHttJ6qYVA15nZ66Z9PRzDpXJYiyEftqNTwz7EM+rBTggEJc9hdoHYkI7FNykghGF2Se2UedMxu67Qacs+6eZ5EDfYsN0ynLIzq4k1gd0WcheLm6ng6ty7U7VCpKbyhzFxZbvTrwV2Wv2zEnG1XCH5R8KSw1hSqbEWHUSfA3QoMirvk4=
This works because sigT is "template universe polymorphic" https://coq.github.io/doc/master/refman/language/cic.html#template-polymorphism which makes every application inhabit as low a universe as the arguments allow.
There's also "universe polymorphism" https://coq.github.io/doc/master/refman/addendum/universe-polymorphism.html which is more regular (eg can be used for any definition rather than just inductives) but currently cannot be instantiated with Prop.
Gaëtan Gilbert
On 23/09/2019 05:05, Jeremy Dawson wrote:
Hi,
I have an example where I'm confused about the rules regarding types.
I have a function GiT of the following type
ljt_dec < Check GiT.
GiT : list PropF -> PropF -> nat -> Prop
ljt_dec < Check (GiT Γ P 0).
GiT Γ P 0 : Prop
The following is accepted without a type error
ljt_dec < Check (existsT2 d : nat, GiT Γ P d).
existsT2 d : nat, GiT Γ P d : Set
existsT2 is notation for sigT ...
ljt_dec < Check (sigT (fun d : nat => GiT Γ P d)).
ljt_dec < Check sigT.
sigT : forall A : Type, (A -> Type) -> Type
but sigT wants a body of type Type (ie nat -> Type)
but in the example works with a body of type
(nat -> Prop)
and sigT should return result type of Type, but here
returns a result of type Type
Sometimes (often) coq objects when you get Prop, Set and
Type mixed up, and use the wrong one, here not at all.
I'd like to understand why this is so
Thanks
Jeremy
- [Coq-Club] sigT and Prop, Jeremy Dawson, 09/23/2019
- Re: [Coq-Club] sigT and Prop, Dominique Larchey-Wendling, 09/23/2019
- Re: [Coq-Club] sigT and Prop, Gaëtan Gilbert, 09/23/2019
