coq-club - [Coq-Club] PhD / Postdoc position at Open University of The Netherlands
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] PhD / Postdoc position at Open University of The Netherlands
  • Date: Mon, 7 Oct 2019 10:50:57 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=freek AT vt.edu; spf=Pass smtp.mailfrom=freek AT vt.edu; spf=None smtp.helo=postmaster AT omr1.cc.vt.edu
  • Ironport-phdr: 9a23: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
PhD and postdoctoral positions in Formal Methods and Decompilation
Open University of The Netherlands / VirginiaTech (USA)
Multiple positions are available at the Open University of The Netherlands (https://ou.nl) and the Systems Software Research Group at Virginia Tech (https://www.ssrg.ece.vt.edu/) on projects on formal methods and reverse engineering of binaries. We are interested in decompilation: retrieving source code from a binary while maintaining a formal correctness proof that everything is sound. This will make bottom-up formal verification possible: applying formal verification to binaries, instead of to source code. If you have an interest in one of the fields of formal methods, (de)compilation, low-level assembly code or reverse-engineering, then you must certainly apply. We can hire both ''promovendi'' (PhD students) and postdocs on this project. Unique about the project is:
The project has close ties to interested parties with relevant case studies.
It is a close collaboration between a Dutch and a US university and if requested there is the possibility of extended visits to the US.
You can choose your own work location in The Netherlands (Amsterdam, Utrecht, Nijmegen, Eindhoven, ...)
Applications can be done by sending your CV and a short application letter indicating your interest in the project via e-mail: fvb -- at -- ou.nl. For more information, see http://www.cs.ru.nl/~freekver/positions/
  • [Coq-Club] PhD / Postdoc position at Open University of The Netherlands, Freek Verbeek, 10/07/2019
