- To: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coqide 8.10
- Date: Sat, 26 Oct 2019 11:41:49 +0200
Hi,
Yes, this is related to the switch to Gtk+3. The event which was used
in gtk+2 to position the handle between the source pane and the
goals and messages panes works differently in Gtk+3 and we replaced it
by a (heuristical) precomputation of the position. Could you post an
image of what you get at https://github.com/coq/coq/issues/10956,
indicating also your configuration: platform, window manager (if
relevant), values of your window height and width in preferences, ...
Thanks in advance.
Best,
Hugo
On Sat, Oct 26, 2019 at 09:45:24AM +0200, Robbert Krebbers wrote:
> This sounds like the same issue as https://github.com/coq/coq/issues/10956
> On 26/10/2019 06.17, Ian Zimmerman wrote:
> > I just upgraded and I see some annoying changes. I'm not sure if they
> > are really changes in coqide, or rather consequences of the switch to
> > Gtk 3.
> > The most maddening one is that as I open each new file the width of the
> > source pane shrinks to be something like 75 columns of my font. Is
> > there a way to stop that? Please?
- [Coq-Club] coqide 8.10, Ian Zimmerman, 10/26/2019
- Re: [Coq-Club] coqide 8.10, Robbert Krebbers, 10/26/2019
- Re: [Coq-Club] coqide 8.10, Hugo Herbelin, 10/26/2019
- Re: [Coq-Club] coqide 8.10, Ian Zimmerman, 10/26/2019
- Re: [Coq-Club] coqide 8.10, Hugo Herbelin, 10/27/2019
