- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] ocaml version required for coq 8.10.1
- Date: Mon, 28 Oct 2019 18:06:36 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=caoqinxiang AT gmail.com; spf=Pass smtp.mailfrom=caoqinxiang AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi1-f176.google.com
- Ironport-phdr: 9a23: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
Aha. Yes, it said 4.02.3. I just need to fix that. Thank you very much!
BTW, now I have the following lines in the end when I "make world" for Coq (if I install ocaml-bytecode):
File "topbin/coqc_bin.ml", line 1:
Error: The file /usr/local/lib/ocaml/nums.cma is not a bytecode object file
make[1]: *** [bin/coqc.byte] Error 2
make: *** [submake] Error 2
Or the following if I install ocaml native-code:
COQMKTOP -o bin/coqc.opt
Error: The file /usr/local/lib/ocaml/nums.cmxa is not a compilation unit description
make[1]: *** [bin/coqc.opt] Error 2
I am trying to fix this. But any quick solutions? Thanks a lot!
Qinxiang Cao
Shanghai Jiao Tong University, John Hopcroft Center
Room 1110-2, SJTUSE Building
800 Dongchuan Road, Shanghai, China, 200240
On Mon, Oct 28, 2019 at 5:08 PM Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net> wrote:
What does "ocamlfind ocamlc -version" say?
Gaëtan Gilbert
On 28/10/2019 10:04, Cao Qinxiang wrote:
> Dear Coq clubbers,
> I try to compile Coq 8.10.1 from source code today. It requires ocaml
> 4.05.0 or later. I had ocaml 4.02.3 previously and build ocaml 4.09.0
> from source code today (make world + sudo make install).
> Now, if I "./configure" in coq 8.10.1 source code folder, I still get:
> Your version of OCaml is 4.02.3.
> You need OCaml 4.05.0 or later.
> Configuration script failed!
> But "ocamlc -v" gives me:
> The OCaml compiler, version 4.09.0
> Standard library directory: /usr/local/lib/ocaml
> Do you have any idea how should I fix this? Thank you very much!
> Best,
> Qinxiang Cao
- [Coq-Club] ocaml version required for coq 8.10.1, Cao Qinxiang, 10/28/2019
- Re: [Coq-Club] ocaml version required for coq 8.10.1, Gaëtan Gilbert, 10/28/2019
- Re: [Coq-Club] ocaml version required for coq 8.10.1, Cao Qinxiang, 10/28/2019
