coq-club - Re: [Coq-Club] universe inconsistency on import
  • To: coq-club <coq-club AT inria.fr>
  • Cc: Vadim Zaliva <vzaliva AT cmu.edu>
  • Subject: Re: [Coq-Club] universe inconsistency on import
  • Date: Fri, 29 Nov 2019 21:15:28 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f46.google.com
  • Ironport-phdr: 9a23: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
If you `Set Printing Universes` before you do the Require Import, you will get more info, often enough to figure out which file they're in.  If you then print the file (with printing universes on), you can figure out which definition the universes come from (figuring out where the constraints come from is much harder, unfortunately).
On Fri, Nov 29, 2019, 20:08 Brett Gilio <brettg AT posteo.net> wrote:
Vadim Zaliva <vzaliva AT cmu.edu> writes:
> I have `Require Import` which fails with the "universe inconsistency" error. There is no more detail besides this message. Any hints on how one can debug this?
> Vadim
> Vadim Zaliva
> A button for name playback in email signature
> CMU ECE Ph.D. candidate
> Mobile/Signal/WhatsApp: +1(510)220-1060
Hello Vadim,
Can I see an example of what you are trying to achieve? Sometimes a
universe inconsistency error can point to an error with logic in the import.
Brett M. Gilio
https://git.sr.ht/~brettgilio/
