- From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>, roux cody <cody.roux AT gmail.com>
- Subject: Re: [Coq-Club] Can you name the biggest number?
- Date: Mon, 2 Dec 2019 14:44:42 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=exmail.nottingham.ac.uk; dmarc=pass action=none header.from=exmail.nottingham.ac.uk; dkim=pass header.d=exmail.nottingham.ac.uk; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=4w3N4UIeWrIFJkuvT/nTaTZjx+2Wm5o5icHZHn6LE9E=; b=ClEpeLQ8QZdXpywrEtbRT8BmBNiipGdg7oDWixborAFuWjJH3ZYfJLxFSTA0YclxRgxvv0MvOLQNFCwWsKHhRw4lzXqztPoMgi7HjEk2nnIQRVSbvIOBq9RlmNbBH4ggAjchlixj/kN2meRNaBDUoDWnZcpTrIL1gh/e010GDjA02/t6h3AYRiGQBO9AQBGgl2rLJgaPtEg+C+Ff2FbXzieATcCVyCRYaQ5fd5gNs+eICQGpK5QQrO6hnl8kbDBWRJRauoDC2Rpq1q8j6InWfPCTj0puahyQD0WTwk2bmUYmfSd35GVQ0spH0AbqKcS4D4qGHsxLm7+72m6eHYhG1Q==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=Qr5DlJGBjxGnT5yo3KoNCoPhbKTXBkCgCLq6lQDRflh6uUg8ImRA6O7xgw95tJLO2sxhqdFkF/JmUL3etQ6xylaU1+Wkmhb1w3lD9j3dbcvBoBJts3XNToWpDqDB4yXDhDtU5B5oyTGrSCsxhypK/Pmfl5UL9wtqaWmdmRyQahDwruxBOerU/eP+ufrtFFPYiCenuWFps+0rVVdCfc+VqsGJj6JA1lEL8QJUndFKHz+P2kVSUlIdAqQ5G7lDYioY9yj9EMidg9msryStweD/LUbAXSJ0v3Ua3EVweI4XzuTPFH7kVmrdLzB7rtMXiy4D+Gf73l1vTQN8hLntQAjK+A==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=Pass smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx01.nottingham.ac.uk
- Ironport-phdr: 9a23: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
Does Coq still allow impredicativity? In any case as part of this you need to prove that the termination is terminating which seems to include that at least some fragment of CoC is terminating. I guess that you have a stronger system because you have some extra universes? Still that is a bit of work.
Given the condition on the proof it would be easier to obtain a fast growing function using ordinals. However, a fast growing function on its own isn’t so useful because you have to produce just one number and it is not obvious when exactly your function will do this. Hence, I am not sure whether this is so helpful given the conditions you gave.
Thorsten
<coq-club-request AT inria.fr> on behalf of roux cody <cody.roux AT gmail.com>
Someone else just pointed this out to me! As I was saying, I'd be happy to declare this the winning entry, as long as it was formalized in Coq and proven to be larger than current contender :).
Cody
On Mon, Dec 2, 2019, 8:18 AM Emilio Jesús Gallego Arias <e AT x80.org> wrote:
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please contact the sender and delete the email and attachment. Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham. Email communications with the University of Nottingham may be monitored where permitted by law. |
- [Coq-Club] Can you name the biggest number?, roux cody, 12/01/2019
- Re: [Coq-Club] Can you name the biggest number?, Emilio Jesús Gallego Arias, 12/02/2019
- Re: [Coq-Club] Can you name the biggest number?, roux cody, 12/02/2019
- Re: [Coq-Club] Can you name the biggest number?, Thorsten Altenkirch, 12/02/2019
