- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "Lean is like Coq but better"
- Date: Thu, 2 Jan 2020 18:32:50 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-stata.csail.mit.edu
- Ironport-phdr: 9a23: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
On 1/2/20 6:00 PM, Kevin Buzzard wrote:
On Thu, 2 Jan 2020 at 21:55, Adam Chlipala <adamc AT csail.mit.edu>
wrote:
I'm not sure I understand
this point. Ltac works well for most kinds of
tactic programming. At least, I don't see how it could be held not to
meet the binary requirement of "a rich programming environment with
useful abstractions."
I am not a computer scientist and I don't have much
experience with Coq,
but with Lean you only need to learn one language not
two,
and as well as
writing tactics people have been writing things like
linters, new commands
which tell you which namespace you're in, which
namespaces are open,
what variables you have and so on, stuff which makes the
end users life
a bit easier.
In general, I think it's a mistake to compare proof
assistants using
criteria associated with random varieties of open-source projects, since
typically open-source projects are much less involved in major
design-space innovations. IMO, worrying about quality of library
ecosystems should mostly be avoided.
When mathematicians come looking at these systems, one of
the first questions
they seem to ask is "how much mathematics is in there
already?".
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", (continued)
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Théo Zimmermann, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Talia Ringer, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", BEGAY Pierre-leo, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Frédéric Blanqui, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Vincent Semeria, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Thorsten Altenkirch, 01/04/2020
- Re: [Coq-Club] "Lean is like Coq but better", Kevin Buzzard, 01/03/2020
- Re: [Coq-Club] "Lean is like Coq but better", Adam Chlipala, 01/03/2020
- Re: [Coq-Club] "Lean is like Coq but better", Talia Ringer, 01/03/2020
- Re: [Coq-Club] "Lean is like Coq but better", Beta Ziliani, 01/03/2020
- Re: [Coq-Club] "Lean is like Coq but better", Timothy Carstens, 01/03/2020
- Re: [Coq-Club] "Lean is like Coq but better", Jason Gross, 01/03/2020
