- To: Kinan Dak Albab <babman AT bu.edu>
- Cc: coq-club AT inria.fr, Hugo.Herbelin AT inria.fr
- Subject: Re: [Coq-Club] Fwd: "Lean is like Coq but better"
- Date: Sun, 12 Jan 2020 11:45:23 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=monnier AT iro.umontreal.ca; spf=Pass smtp.mailfrom=monnier AT iro.umontreal.ca; spf=None smtp.helo=postmaster AT mailscanner.iro.umontreal.ca
- Ironport-phdr: 9a23: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
> This is why I do not really care if Coq (or lean or agda or anything
> else's) proofs are readable or not when it comes to program verification.
As a user of the program, that makes sense. But if you ever intend to
work (extend, modify, ...) on that program (or pay someone else to do
it), then you'll need this proof to be readable, just like you need the
code to be readable, otherwise you won't be able to update the proof to
match the new code.
Stefan
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", (continued)
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Thorsten Altenkirch, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Conor McBride, 01/10/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Timothy Carstens, 01/10/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Tadeusz Litak, 01/10/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Conor McBride, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Tadeusz Litak, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Hugo Herbelin, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Siddharth Bhat, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kinan Dak Albab, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Stefan Monnier, 01/12/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Adam Chlipala, 01/12/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kinan Dak Albab, 01/12/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Timothy Carstens, 01/13/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Xuanrui Qi, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Timothy Carstens, 01/11/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Timothy Carstens, 01/12/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Conor McBride, 01/12/2020
