coq-club - Re: [Coq-Club] universe inconsistency
  • From: Christian Doczkal <christian.doczkal AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] universe inconsistency
  • Date: Mon, 13 Jan 2020 10:25:17 +0100
Dear Jeremy,
There was a thread started by Vadim Zaliva on Nov. 30th, 2019 with
subject "universe inconsistency on inport". That thread developed into a
discussion on how to debug universe inconsistencies, e.g., by naming the
universes introduced by key (monomorphic) definitions. Maybe it can
serve as a starting point?
Hope that helps!
Christian
On 1/13/20 6:37 AM, Jeremy Dawson wrote:
> Hi,
> Following the problem described in the message below, I've spent a very
> great deal of time inserting Polymorphic in various definitions,
> more-or-less randomly, and it often seems to make a difference,
> sometimes by avoiding an error but sometimes by producing similar errors
> somewhere else. This doesn't help, and as a result it's making Coq
> virtually unusable for me.
> Trying random changes to see if it works isn't my idea of how to go
> about doing proofs (or anything else), and certainly not something I'd
> recommend and certainly so I really would appreciate some guidance on this.
> In particular, the latest error I've got is
> Unable to unify
> "seqrel@{Top.598 Top.602 Top.600} (singleton_rel ([], [Imp C D]) ([C],
> [D]))
> c2 x" with "seqrel@{Top.775 Set Top.772} ?R c2 x"
> what does seqrel@{Top.598 Top.602 Top.600} mean?
> And I get the following
> can_trf_ImpRinv_ImpL' < Check seqrel.
> seqrel@{Top.777 Top.778
> Top.779}
> : forall W : Type@{Top.778},
> (rel (list W) -> rel (list W) -> Type@{Top.779}) ->
> relationT@{lntT.6 Top.777} (Seql W)
> (* {Top.779 Top.778 Top.777 Top.775 Top.772 Top.749} |=
> Set <= Top.602
> Set <= Top.749
> (and about a screenful more of similar inequalities)
> I've seen a bit about universe inequality constraints in
> http://adam.chlipala.net/cpdt/html/Cpdt.Universes.html
> but apart from that, what does this mean?
> Thanks for any help
> Jeremy
> On 25/12/19 11:15 pm, Jeremy Dawson wrote:
>> Hi,
>> I've got the following error message
>> The term "rr" has type
>> "(rel (list W) -> rel (list W) -> Type@{Top.890}) -> Type@{Top.889}"
>> while it is expected to have type
>> "(rel (list W) -> rel (list W) -> Type@{k4.86}) -> Type@{Top.897}"
>> (universe inconsistency: Cannot enforce k4.86 <= Top.890 because Top.890
>> < Top.688 <= gstep.624 = k4.86).
>> How do I find out why Coq wants Top.890 < Top.688 and Top.688 <=
>> gstep.624 and gstep.624 = k4.86 ?
>> Is this the sort of error which is likely to be solved by putting
>> Set Universe Polymorphism? (When I tried this it led to errors
>> elsewhere so I didn't pursue this idea).
>> Thanks
>> Jeremy Dawson
