- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Safe to download and compile .v from evil source ?
- Date: Sun, 2 Feb 2020 14:44:39 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-stata.csail.mit.edu
- Ironport-phdr: 9a23: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
It sounds like a fun project, actually. Maybe the most pragmatic mode is to check .v files for non-misleading correspondence with the final conclusions of .vo files (rather than building a pretty-printer that just starts from the .vo file and no presentation advice).
On 2/2/20 2:34 PM,
jonikelee AT gmail.com
wrote:
On Sun, 2 Feb 2020 09:51:46 -0500
Adam Chlipala
<adamc AT csail.mit.edu>
wrote:
The clear community recommendation would be toIf the tools you requested above existed, I might be able to see that
check .vo files, not .v files. However, that mode requires
additional code-review tools that pretty-print crucial parts of .vo
files in sufficiently readable ways (definitely not involving Ltac,
plugins, etc., and in fact with no need to display proof terms, just
"final" theorem statements and their dependencies).
this is the case! So, that request gets a +1 from me.
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, (continued)
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Jason Gross, 02/02/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, jonikelee AT gmail.com, 02/02/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Adam Chlipala, 02/02/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Théo Zimmermann, 02/02/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Emilio Jesús Gallego Arias, 02/02/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Timothy Carstens, 02/03/2020
- Re: [Coq-Club] Safe to download and compile .v from evil source ?, Timothy Carstens, 02/02/2020
