coq-club - Re: [Coq-Club] consistency
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] consistency
  • Date: Mon, 3 Feb 2020 10:46:49 +0100 (CET)
Hi,
Well to my knowledge, "consistency" is not defined in Coq.
If what you mean is how to prove inconsistency from 0=1
without going through False, this is a way, by pattern
matching which is essentially a decomposition of
what "discriminate" does.
Section absurdum.
  Fact zero_eq_one_absurd : 0 = 1 -> forall P : Prop, P.
  Proof.
    intros H P.
    set (f := fun n => match n with 0 => True | _ => P end).
    change (f 1).
    rewrite <- H.
    exact I.
  Qed.
End absurdum.
Check zero_eq_one_absurd.
It also works as is for (P : Type) at the cost of "singleton
elimination" (SE). But it can also be done for P:Type
w/o SE. It is a bit more complicated though.
Best,
Dominique
De: "Patricia Peratto" <psperatto AT vera.com.uy>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Dimanche 2 Février 2020 01:16:55
Objet: [Coq-Club] consistency
Can not be defined that different constructors are
different terms automatically?
To not use bottom to prove 0<>1.
To be consistent.
Regards,
Patricia Peratto
  • [Coq-Club] consistency, Patricia Peratto, 02/02/2020
    • Re: [Coq-Club] consistency, Dominique Larchey-Wendling, 02/03/2020
