- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] loadpath
- Date: Wed, 5 Feb 2020 08:34:33 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=artagnon AT gmail.com; spf=Pass smtp.mailfrom=artagnon AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua1-f49.google.com
- Ironport-phdr: 9a23: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
Try `coq_makefile -f _CoqProject -o Makefile`.
R.
On Wed, Feb 5, 2020 at 8:33 AM Jeremy Dawson <Jeremy.Dawson AT anu.edu.au> wrote:
Thanks - but coq_makefile doesn't generate a Makefile - it does generate
a file called CoqMakefile.conf
Is coq_makefile documented? It's not in the index (ie
https://coq.inria.fr/distrib/current/refman/genindex.html
Is this where I should be looking for documentation? )
And the man page is hardly helpful
Thanks
Jeremy
On 5/2/20 6:14 pm, Ramkumar Ramachandra wrote:
> Hi Jeremy,
> You need to set up an `_CoqProject` like this:
> -Q category Cat
> category/cat.v
> category/ncat.v
> ... and run `coq_makefile` to generate a Makefile. Note that if you can
> `make` the project, then Coq should work from Emacs just fine.
> In the example I've supplied, "category" is the subdirectory you want to
> include, and you'd use `From Cat Require Import ...` to include a file
> in it.
> R.
> On Wed, Feb 5, 2020 at 8:09 AM Jeremy Dawson <Jeremy.Dawson AT anu.edu.au
> <mailto:Jeremy.Dawson AT anu.edu.au>> wrote:
> Hi,
> The documentation at
> https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#coq:cmd.load
> says
> This command loads the file named ident.v, searching successively
> in each of the directories specified in the loadpath. (see Section
> Libraries and filesystem)
> but when I go to that section it doesn't tell you how to set a
> "loadpath" or how to view what it is (or even what it is, so I've
> got to
> guess it's as in other languages that I'm familiar with - and that
> somehow doesn't seem to fit the case)
> So how do I load a file (eg, ttt/TTT/sss.v)
> Thanks
> Jeremy
- [Coq-Club] loadpath, Jeremy Dawson, 02/05/2020
- Re: [Coq-Club] loadpath, Ramkumar Ramachandra, 02/05/2020
- Re: [Coq-Club] loadpath, Jeremy Dawson, 02/05/2020
- Re: [Coq-Club] loadpath, Pierre Courtieu, 02/05/2020
