coq-club - [Coq-Club] Regarding the properties of a verified beta-reduction evaluator for the untyped lambda calculus
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Regarding the properties of a verified beta-reduction evaluator for the untyped lambda calculus
  • Date: Sun, 9 Feb 2020 19:24:43 +0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=i.donaldl AT me.com; spf=Pass smtp.mailfrom=i.donaldl AT me.com; spf=None smtp.helo=postmaster AT pv50p00im-zteg10011401.me.com
  • Ironport-phdr: 9a23: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
Dear coq-clubbers,
I have recently been looking into the untyped lambda calculus (UTLC) and its
formalization in Coq which lead to a question about the properties of a
verified beta-reduction evaluator for said calculus. But first, some
background: suppose we define the syntax of lambda terms in the UTLC as
follows:
```coq
Inductive tm : Type :=
| Var : nat -> tm (* deBruijn index *)
| App : tm -> tm -> tm (* M N *)
| Abs : tm -> tm. (* \. M *)
Then lifting and substitution (as defined in Iron Lambda:
http://iron.ouroborus.net):
```coq
Fixpoint lift (depth : nat) (term : tm) : tm :=
match term with
| Var n => if lt_dec n depth then Var n else Var (S n)
| App M N => App (lift depth M) (lift depth N)
| Abs M => Abs (lift (S depth) M)
end.
Fixpoint subst (depth : nat) (u term : tm) : tm :=
match term with
| Var n =>
match lt_eq_lt_dec n depth with
| inleft (left _) => Var n
| inleft (right _) => u
| inright _ => Var (n - 1)
end
| App M N =>
App (subst depth u M) (subst depth u N)
| Abs M =>
Abs (subst (S depth) (lift 0 u) M)
end.
And single-step beta reduction, using evaluation contexts (again, following
the style of Iron Lambda):
```coq
Inductive eval_ctx : (tm -> tm) -> Prop :=
| eval_ctx_top :
eval_ctx (@id tm)
| eval_ctx_app_left : forall N,
eval_ctx (fun M => App M N)
| eval_ctx_app_right : forall M,
eval_ctx (App M)
| eval_ctx_abs :
eval_ctx Abs.
(* Single-step beta reduction *)
Inductive beta_step : tm -> tm -> Prop :=
| beta_step_subst : forall M N,
beta_step (App (Abs M) N) (subst 0 N M)
| beta_step_ctx : forall C term term',
eval_ctx C ->
beta_step term term' ->
beta_step (C term) (C term').
Notice that our single-step beta-reduction relation is nondeterministic. Now,
I have been able to implement and prove correct a single-step beta-reduction
evaluator which returns Some t’ if the given lambda term can take a step to
t’, and None otherwise:
```coq
Parameter beta_step_eval : tm -> option tm.
It has been proven correct in the sense that 1) it only ever performs valid
beta-reduction steps and 2) it is always able to reduce lambda terms with
beta-redexes:
```coq
(* Our beta single-step evaluator only performs valid
beta-reduction steps *)
Axiom beta_step_eval_sound : forall t t',
beta_step_eval t = Some t' ->
beta_step t t'.
(* Our beta single-step evaluator is always able to reduce
lambda terms with beta-redexes *)
Axiom beta_step_eval_complete : forall t t',
beta_step t t' ->
exists t'', beta_step_eval t = Some t''.
Now, define the multi-step beta-reduction relation to be the reflexive,
transitive closure of `beta_step`:
```coq
From Coq Require Import Relations.
Definition beta_multistep : tm -> tm -> Prop :=
clos_refl_trans_1n tm beta_step.
It is easy to implement a multi-step beta-reduction evaluator based on some
gas parameter `n` which performs at most `n` beta-reduction steps based on
`beta_step` (implementation elided):
```coq
Parameter beta_multistep_eval : nat -> tm -> tm.
To show that this multi-step evaluator is correct, we could first prove that
it only performs valid beta-reduction steps similar to what we did for our
single-step evaluator, which follows directly by induction on the gas
parameter (proof elided):
```coq
Axiom beta_multistep_eval_sound : forall gas t t',
beta_multistep_eval gas t = t' ->
beta_multistep t t'.
However, this property alone is not enough to show that our implementation of
`beta_multistep_eval` is correct, because the trivial implementation that
never performs any beta-reduction steps also satisfies this property (by
matching the `rt1n_refl` constructor unconditionally):
```coq
Definition beta_multistep_eval (_ : nat) (t : tm) : tm := t.
I have not been able to come up with a property analogous to
`beta_step_eval_complete` for the multi-step evaluator. Are there any
properties other than `beta_multistep_eval_sound` above relating
`beta_multistep` and `beta_multistep_eval` that successfully differentiates a
proper implementation of `beta_multistep_eval` from the trivial
implementation shown above? Any ideas would be much appreciated.
Yours sincerely,
Donald
P.S. I was thinking of stating and proving that our multistep evaluator
always reduces a lambda term to some beta-normal form within a finite number
of steps given that the lambda term has a beta-normal form, something like:
```coq
Theorem beta_multistep_eval_complete : forall t t',
beta_multistep t t' ->
beta_normal_form t' ->
exists gas, beta_multistep gas t = t'.
However, it occurred to me this morning that even if a lambda term in the
UTLC has a beta-normal form, certain choices of reduction steps may still
fail to terminate, implying that a multi-step evaluator may not always choose
the correct reduction steps to reach a beta-normal form for a lambda term,
provided that there is one. Or is it possible to implement the evaluator in
such a way that it always chooses the correct reduction steps towards a
beta-normal form (if exists)?
