- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Abandoned proof engineering efforts
- Date: Sun, 16 Feb 2020 17:09:28 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f52.google.com
- Ironport-phdr: 9a23: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
I think fiat-parsers might count https://github.com/mit-plv/fiat/tree/master/src/Parsers
On Sat, Feb 15, 2020, 20:28 Talia Ringer <tringer AT cs.washington.edu> wrote:
Hi all,I'm curious if any of you have ever started to verify a system, but then abandoned that system due to the difficulty of evolving and maintaining your proofs. If so, I would love for you to share those proof efforts with me, especially if the code is public.Thanks!Talia
- [Coq-Club] Abandoned proof engineering efforts, Talia Ringer, 02/16/2020
- Re: [Coq-Club] Abandoned proof engineering efforts, Talia Ringer, 02/16/2020
- Re: [Coq-Club] [isabelle] Abandoned proof engineering efforts, Christoph Sprenger, 02/18/2020
- Re: [Coq-Club] Abandoned proof engineering efforts, Jason Gross, 02/16/2020
- Re: [Coq-Club] [isabelle] Abandoned proof engineering efforts, Denis Nikiforov, 02/18/2020
- RE: [Coq-Club] [isabelle] Abandoned proof engineering efforts, Fernandez, Matthew, 02/18/2020
- Re: [Coq-Club] [isabelle] Abandoned proof engineering efforts, Stephan Merz, 02/18/2020
- Re: [Coq-Club] Abandoned proof engineering efforts, Jan Bessai, 02/18/2020
