- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] Satisfiability Checking and Symbolic Computation - Call for Papers
- Date: Tue, 3 Mar 2020 09:49:39 -0500 (EST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=geoff AT cs.miami.edu; spf=Pass smtp.mailfrom=geoff AT cs.miami.edu; spf=None smtp.helo=postmaster AT mail-qt1-f227.google.com
- Ironport-phdr: 9a23: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
The 5th International Workshop on
Satisfiability Checking and Symbolic Computation (SC-Square 2020)
July 5th, 2020, Paris, France
http://www.sc-square.org/CSA/workshop5.html
Affiliated with IJCAR 2020:
https://ijcar2020.org/
==== Key Dates
Submissions: Fri. 10 April 2020
Notification: Fri. 8 May 2020
Final version: Fri. 29 May 2020
Workshop: Sun. 5 July 2020
==== Scope
Symbolic Computation is concerned with the efficient algorithmic determination
of exact solutions to complicated mathematical problems. Satisfiability
Checking has recently started to tackle similar problems but with different
algorithmic and technological solutions.
The two communities share many central interests, but researchers from these
two communities rarely interact. Also, the lack of common or compatible
interfaces for tools is an obstacle to their fruitful combination. Bridges
between the communities in the form of common platforms and road-maps are
necessary to initiate an exchange, and to support and direct their
interaction.
The aim of this workshop is to provide an opportunity to discuss, share
knowledge and experience across both communities.
The topics of interest include but are not limited to:
+ Satisfiability Checking for Symbolic Computation
+ Symbolic Computation for Satisfiability Checking
+ Applications relying on both Symbolic Computation and Satisfiability
Checking
+ Combination of Symbolic Computation and Satisfiability Checking tools
+ Decision procedures and their embedding into SMT solvers and computer
algebra systems
==== Submission Guidelines
Submissions should be in English, formatted in Springer LNCS style and
submitted via EasyChair using this link:
https://easychair.org/my/conference?conf=scsquare2020
We invite three types of submissions:
+ NP: Normal papers describing research not published or submitted elsewhere
(with a limit of 15 pages).
+ EA: Extended abstracts may be position papers, description of research
prospects, challenges, projects, ongoing works, or applications relevant
to SC-square (with a limit of 8 pages).
+ PO: Posters
To receive the appropriate level of peer review, please declare the category
of your submission by prefixing the title on the EasyChair form with "NP",
"EA" or "PO" accordingly.
For consistency, all submissions must use the LNCS style. The style files are
here:
https://www.springer.com/gp/computer-science/lncs/conference-proceedings-guidelines
We plan to publish the post proceedings of the workshop in digital form
either
in EasyChair EPiC series or as a special issue in a journal. Authors may opt
out of this, should they prefer to publish the material elsewhere.
People from industry and business are warmly invited to submit papers to
describe their problems, challenges, goals, and expectations for the
SC-square
community.
==== Program committee:
Konstantin Korovin (Co-Chair) (University of Manchester, UK)
Ilias Kotsireas (Co-Chair) (Wilfrid Laurier University, Canada)
Erika Abraham (RWTH Aachen University)
Curtis Bright (University of Waterloo)
James H. Davenport (University of Bath)
Matthew England (Coventry University)
Vijay Ganesh (Waterloo University)
Marijn Heule (Carnegie Mellon University)
Ahmed Irfan (Stanford University)
Dejan Jovanovic (SRI International)
Manuel Kauers (Johannes Kepler University, Linz)
Stefan Ratschan (Institute of Computer Science, Czech Academy of Sciences)
Martina Seidl (Johannes Kepler University, Linz)
Thomas Sturm (CNRS)
<TBA>
==== Venue
Affiliated with IJCAR, 29 June - 5th July, 2020, Paris, France
- [Coq-Club] Satisfiability Checking and Symbolic Computation - Call for Papers, geoff, 03/03/2020
