coq-club - Re: [Coq-Club] [Agda] Why dependent type theory?
  • From: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>
  • To: Ettore Aldrovandi <ealdrov AT math.fsu.edu>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, "coq+miscellaneous AT discoursemail.com" <coq+miscellaneous AT discoursemail.com>, lean-user <lean-user AT googlegroups.com>
  • Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
  • Date: Thu, 5 Mar 2020 15:39:13 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=exmail.nottingham.ac.uk; dmarc=pass action=none header.from=exmail.nottingham.ac.uk; dkim=pass header.d=exmail.nottingham.ac.uk; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=/qGENvCT02eJ93ZgfgaH3NqmqdTVOzE4pagKTlLBvbs=; b=I2jvJnVb+sS15jTzc5umY45M5C5EZ2aztPtr3CuOwfc505qxmxexhNt61kw9XrzlMQTvzviORP9PNtGcQ/3hGkVdF4lByUCgKSCSGiQCwoV/gM9lDq8c2m1miSCrNG34UZGJ6D8tezT/1ccN4QJRlzlNaphRSSORYZ2iSdel96fBKfvfaCBdqPam/FwcdCehaVT6Ai2dkKYnH0l01zDf8RGyouKyWt74gn0vnmnErJwpTUlHsdbQQC+Z8kUC4O7a51t69qtjYlO9asV7WaoR/XRce455AI4vRrjJrAo78nt8+Qs9xlMTT8Cd4VgGOSKpsx0H4Q6KvQb4Ed8lSavIlA==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=gyYyoO3hEifmvR+I7YObwE19+XleCI9H2s3Jg6O0gCg4GzM60Bv7RZkzoyqx/iU4wRBiqCrBvdMXzQ9OQbvz7djfNK9dTTWg7np3Q9pP/jTKuyGMiHtwj0t9UxE/fzfW1B18h3Z6iMTWNwow98uTZ+zu1z2A4w9R1rI/ucs8WAlgTz/7EcnjjfXxhsWyMfLfcndNsUha+ri6qtLqdXubgoyutaFHS7r2RW+VlKv6MdVcfS5DYiQgz1FIzaNMWgotx5KsbJRNqnjPgCga53WoYB4wkTLXTnCwGy+gwtbTfo3Ef/rwHW7xtsmSy7rkQXgLl6vjnruo1DGRjkU0w1uqHw==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Thorsten.Altenkirch AT nottingham.ac.uk; spf=Pass smtp.mailfrom=Thorsten.Altenkirch AT nottingham.ac.uk; spf=None smtp.helo=postmaster AT uidappmx02.nottingham.ac.uk
  • Ironport-phdr: 9a23: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
Hi Ettore,
In set theory the union of two sets (written \cup) is the set which contains the elements which are in one set or the other. Hence I cannot see what is “mathematically incorrect” in my example
Cheers,
Thorsten
Date: Wednesday, 4 March 2020 at 21:59
To: Thorsten Altenkirch <psztxa AT exmail.nottingham.ac.uk>
Subject: Re: [Agda] [Coq-Club] Why dependent type theory?
Hi,
I think the example below is not mathematically correct. The problem is that \cup is not the same as \sqcup. The latter is of course a coproduct in the category of sets, whereas the former is  a push-out, so a colimit of a more complicated diagram. In the line
{0,1}  \cup {0,1,2,3} = {0,1,2,3}
of course the two sets {0,1} and {0,1,2,3} are not disjoint, whereas  in the line
{true , false}  \cup {0,1,2,3} = {true,false,0,1,2,3}
the union is actually disjoint, i.e. a coproduct. In the example with the sum,
{0,1}  + {0,1,2,3} = {in1 0,in1 1,in2 0,in2 1,in2 2,in2 3}
{true , false}  + {0,1,2,3} = {in1 true,in1 false ,in2 0,in2 1,in2 2,in2 3}
in the first line {0,1} is actually made disjoint from {0,1,2,3}. To turn this around, suppose you do a push-out
{true, false} \coprod_{0,1} {0,1,2,3}
where you use the maps f : {0,1} -> {true, false} and i : {0,1} ->{0,1,2,3} . Then, since f is an isomorphism, you get something isomorphic to the union.
So, this example doesn’t really show that \cup exposes the implementation. But part of this example becomes possible because  in sets we have naively “disembodied” elements leading to constructions of this sort…
…I guess, I’m just learning this stuff myself. (First post here, actually!)
Best,
—Ettore
On Mar 4, 2020, at 04:42, Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk> wrote:
First of all I don’t like the word “dependent type theory”. Dependent types are one important feature of modern Type Theory but hardly the only one.
To me the most important feature of Type Theory is the support of abstraction in Mathematics and computer science. Using  types instead of sets means that you can hide implementation choices which is essential if you want to build towers of abstraction. Set theory fails here badly. Just as a very simple example: in set theory you have the notion of union, so for example
However, if we change the representation of the first set and use lets say {true,false} we get a different result:
This means that \cup exposes implementation details because the results are not equivalent upto renaming. In Type Theory we have the notion of sum, sometimes called disjoint union, which is well behaved
Unlike \cup, + doesn’t reveal any implementation details it is a purely structural operation. Having only structural operations means that everything you do is stable under equivalence, that is you can replace one object with another one that behaves the same. This is the essence of Voevodsky’s univalence principle.
There are other nice aspects of Type Theory. From a constructive point of view (which should come naturally to a computer scientists) the proporsitions as types explanation provides a very natural way to obtain “logic for free” and paedagogically helpful since it reduces logical reasoning to programming.
There are performance issues with implementations of Type Theory, however, in my experience (mainly agda) the execution of functions at compile time isn’t one of them. In my experience the main problem is to deal with a loss of sharing when handling equational constraints which can blow up the time needed for type checking. I think this is an engineering problem and there are some suggestions how to fix this.
Thorsten
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please contact the sender and delete the email and
attachment.
Any views or opinions expressed by the author of this email do not
necessarily reflect the views of the University of Nottingham. Email
communications with the University of Nottingham may be monitored
where permitted by law.
  • Re: [Coq-Club] [Agda] Why dependent type theory?, Thorsten Altenkirch, 03/05/2020
