- To: coq-club AT inria.fr
- Subject: [Coq-Club] Lambda-calculus in coq
- Date: Fri, 13 Mar 2020 14:26:47 +0100
Sorry for hitting send too fast !
Hi, I'm trying to implement some kind of non-deterministic λ-calculus.
Anyway, the terms are something like that
Inductive term :=
| var: string -> term
| func: var -> body -> term
with body :=
| choose: list body -> body
| ret: term -> body
| apply: var -> term -> body
| letin: var -> body -> body -> body
And now I'm trying to define the type of values.
So a functional value is a relation between values, because it takes a value
and produces some number of values.
I would like to write something like that :
Inductive value : Type :=
| base: forall t: Type, t -> value
| func: (value -> value -> Prop) -> value.
Of course, this is not working because of non-positivity.
The obvious solution would be to use closures, but we want to be able to
externally define functions (directly in gallina, via a relation) without
having to explicitly define a body for it.
I thought for sure somebody must have already had a similar issue.
By the way, we did a version using step-indexing, but it's not entirely
satisfactory, because it makes the definition hard to use to make a proof.
Thanks in advance !
Louis
pEpkey.asc
Description: application/pgp-keys
- [Coq-Club] Lambda-calculus in coq, Louis Noizet, 03/13/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Lambda-calculus in coq, Thorsten Altenkirch, 03/13/2020
