- From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How do I manage data structures with invariants in Coq?
- Date: Fri, 13 Mar 2020 18:02:38 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=agnishom AT cmi.ac.in; spf=Pass smtp.mailfrom=agnishom AT cmi.ac.in; spf=None smtp.helo=postmaster AT mail.cmi.ac.in
- Ironport-phdr: 9a23:NzcTmxAeR33PO1BMi1OiUyQJP3N1i/DPJgcQr6AfoPdwSP39o8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERLmcAFxO+7dG4jIjs3x2frh1YfUZlBhizy8erN1KV2drQzNqs4OiIdiO68ggk/ArX1JYORRwEtjIFPVlh2658Hmr80ryDhZp/90r50Iaq79ZaltFeUJXgRjCHg84YjQjTeGSAKO4nUGVWBPy0hDBgmD5Rq8X5Gj63Kn5No44zGTOIjNdZ5xWTmm6P41GhrhiSNBPDs4tmjczM123voC/ECR4idnyouRW7m7ceJkd/qEL9gfRCxIVYBQUX4ZDw==
In a similar spirit, I am trying to define a function rotate (f r s : list A) (H : length r = 1 + length f ) : list A
To do this, I am doing the following:
Fixpoint rotate (f r s : list A)
(H : length r = length f + 1) : list A.
refine
(match f, r, s with
| [], [], _ => _
| [], (y :: []), a => y :: a
| [], (y :: _), a => _
| (x :: xs), [], a => _
| (x :: xs), (y :: ys), a => x :: (rotate xs ys (y::a) _ )
end).
refine
(match f, r, s with
| [], [], _ => _
end).
Here, the first three _ on the right is some kind of contradiction. The fourth _ is a proof that the condition for evaluating the function is satisfied.
However, I do not seem to be able to complete this proof. For example, when I try to prove the first case, the fact that f and r are empty lists seem to be lost.
Any help would be appreciated.
--Agnishom
On Tue, Mar 10, 2020 at 6:06 PM mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:
Hi Agnishom,
You can write your Definition in proof mode. I have wrapped your
definition (Gallina term?) in refine tactic, and you can discharge
your proof in tactic mode. Hope it helps.
Definition snoc (q : queue) (x: A) : queue.
refine (
let ans := exec (front q) (x :: rear q) (silly q) in
let s := snd ans in
let f := fst (fst ans) in
let r := snd (fst ans) in
let inv' := (exec_preserves_invariant q f r s x _)
in Build_queue f r s inv').
(* Write your tactic here to discharge the rest of the proof *)
A : Type
q : queue
x : A
ans := exec (front q) (x :: rear q) (silly q) : list A * list A * list A
s := snd ans : list A
f := fst (fst ans) : list A
r := snd (fst ans) : list A
(f, r, s) = exec (front q) (x :: rear q) (silly q)
Best,
Mukesh
On Wed, Mar 11, 2020 at 9:26 AM Agnishom Chattopadhyay
<agnishom AT cmi.ac.in> wrote:
> I am trying to implement a functional queue in Coq. My idea is to add the proof of the invariant as a part of the type. Like this:
> Require Import Coq.Lists.List.
> Import ListNotations.
> Require Import Lia.
> Section Queue.
> Variable A : Type.
> Record queue :=
> front : list A;
> rear : list A;
> silly : list A;
> invariant : length front - length rear = length silly
> Definition empty : queue := Build_queue [] [] [] (eq_refl).
> Definition isEmpty (q : queue) : bool :=
> match (front q) with
> | [] => true
> | _ => false
> end.
> Fixpoint rotate (f : list A) (r : list A) (s : list A) : list A :=
> match f, r, s with
> | [], (y :: _), a => y :: a
> | (x :: xs), (y :: ys), a => x :: (rotate xs ys (y::a))
> | _, _, _ => []
> end.
> Fixpoint exec (f : list A) (r : list A) (s : list A) : list A * list A * list AUTO :=
> match f, r, s with
> | _, _, (x :: xs) => (f, r, xs)
> | _, _, [] => let f' := rotate f r [] in (f', [], f')
> end.
> The following Lemma is to support the next definition
> Lemma exec_preserves_invariant : forall (q : queue),
> forall f r s x ,
> -> length f - length r = length s.
> Proof.
> intros.
> pose proof (invariant q).
> destruct (front q); destruct (silly q).
> - simpl in H. inversion H. simpl. lia.
> - inversion H0.
> replace (length (a :: l)) with (S (length l)) in H0 by reflexivity.
> replace (length (a0 :: l0)) with (S (length l0)) in H0 by reflexivity.
> lia.
> Qed.
> However, I cannot figure out what would be the correct way to replace the underscore below.
> Definition snoc (q : queue) (x: A) : queue :=
> let s := snd ans in
> in
> Build_queue f r s inv '.
> What is the correct way to define the invariant preserving functions such as snoc?
> In some languages like Lean, I have noticed that any term can be replaced by a tactic that synthesizes a similar term. So, in such a context, I could have replaced the underscore by a proof using tactics.
> --Agnishom
- [Coq-Club] How do I manage data structures with invariants in Coq?, Agnishom Chattopadhyay, 03/10/2020
- Re: [Coq-Club] How do I manage data structures with invariants in Coq?, mukesh tiwari, 03/11/2020
- Re: [Coq-Club] How do I manage data structures with invariants in Coq?, Agnishom Chattopadhyay, 03/14/2020
- Re: [Coq-Club] How do I manage data structures with invariants in Coq?, mukesh tiwari, 03/14/2020
- Re: [Coq-Club] How do I manage data structures with invariants in Coq?, Dominique Larchey-Wendling, 03/14/2020
