coq-club - Re: [Coq-Club] Non-strict positivity and impredicativity
  • From: Fredrik Nordvall Forsberg <fredrik.nordvall-forsberg AT strath.ac.uk>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Non-strict positivity and impredicativity
  • Date: Wed, 18 Mar 2020 15:20:29 +0000
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=strath.ac.uk; dmarc=pass action=none header.from=strath.ac.uk; dkim=pass header.d=strath.ac.uk; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=FQEwE5mKOrOQcBGHQbm48slBvIGKuSTrv/xR31I8C/A=; b=SQkcndDVWxtssKNdXSRlFCuWo8K5y9rmvAGvcsHqmOUKvkI592UHshU3hkvoH6zBy2+wNIrjTmMOUSmQknaEaoQuXEWhaUHILgTw4CHqEbaf3AaR7jmi4hSt0AALOmo93kLTV14nPFNRHHP5khO/6mZi/QjiiEpU/sowB2DOes5LyFAk1nWBlyOtkM6qL/x22SFgJlwWelq1c5ieTqdl9AGKkCOwh2Mos7lv7BMpMAzeP9AM0nVNN5jN07GzrGq2M1WDGZV/5S5qDpjfQcdoXxq9MM1w+kelp6KJZNzXZuyZFwR1VhXVI6XtZcrj+KP8uBOWYrpV0D+iKRFBN9nyfg==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=MM2kZc+EYbyNTtCA83ZLx/Me5OO0iBP2IyRIJpEMM3MA1Itu7KUxvlNgQRdgBuNDvEn9cYiiLHhFhsc9Umw2tahxzzWpQ+NqYB6HL5XdwSnM9nArccju+9fR88WHwfgGxrVBUa+xl/t4ShhGXYhhGIHvCLMoLj2B3+oFO1mIfSltVd9O1uZsG6jL1jHbae92+oLRyZCUcRcrc5P03bfh5vo1Ji35DhO7pfZnXRwGjdjJHjRSyngDGe0TxSK95LIyKvj8FALrpKDJVAkH+tXf/csybZmYDBfOPxx9pQqE31WhtXn4gZ214sUJzOhR9lPFID75r2cgQT6IwHxIk/s28g==
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=fredrik.nordvall-forsberg AT strath.ac.uk; spf=Pass smtp.mailfrom=fredrik.nordvall-forsberg AT strath.ac.uk; spf=Pass smtp.helo=postmaster AT EUR01-DB5-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23:Aw9HRB+SPAcaHP9uRHKM819IXTAuvvDOBiVQ1KB+2+0cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV93a19HsZHgj1HQtzPOX8XIDI3Oqt0OXn1Yfebx9Jh3KbZql+MhyyqU3/sdMNi4Z4Je5lxAHErmFJeKJQwnlkO1uXm1Py4d2r9pN5/AxLp+go684GWK68YqduHu8QNygvL21gvJ6jjhLEVwbaviJBAFVTqQJBBk3+1D+/Xpr1tXel5MdA4nHDeOHcEPUzUznk6Lp3Qhj1jitBLyQ+7Gzcls13iuRcvQ6loBt8hYXTZdPMbaYsTubmZdofAFF5cINJTSUYXtGnc5EGE+pHNO0esoqv/wJf/yv7PhGlAabU8hENg3b32aMg1OF4TVPdwBYpA9JIuX+Ssdanbao=
Dear Stefan,
On 17/03/2020 21:43, you wrote:
> Would it be possible to define an injective function from `X : Type` to
> `X → Prop` if it weren't for Coq's impredicative treatment of indices?
You can use Leibniz equality, which lives in Prop thanks
to impredicativity:
Definition leibniz {X : Type}(a b:X) : Prop := forall P:X -> Prop, P a -> P
b.
Hence already impredicativity + non-strictly positive types
is inconsistent, even in the absence of any notion of inductively
defined propositional equality; just repeat the construction with
Leibniz equality everywhere (see adapted Coq code below). In fact, going
back to the paywalled Coquand Paulin-Mohring paper now, this is the only
notion of equality they use.
Note that just choosing i = leibniz and still formulating eg injectivity
using a non-Prop inductively defined equality does not work: to prove
that i is injective this way, we need to instantiate P : X -> Prop with
equality, which only works if it lives in Prop. But since the paradox is
not using the full J rule, Leibniz equality is enough.
Best wishes,
Fred
Definition leibniz {X : Type}(a b:X) : Prop := forall P:X -> Prop, P a -> P b.
Lemma leibniz_refl {X : Type}(x : X) : leibniz x x.
Proof.
unfold leibniz.
auto.
Qed.
Lemma leibniz_trans {X : Type}{x y z : X} : leibniz x y -> leibniz y z ->
leibniz x z.
Proof.
intros Hxy Hyz.
unfold leibniz.
intros P Px.
apply Hyz.
apply (Hxy P Px).
Qed.
Lemma leibniz_sym {X : Type}{x y : X} : leibniz x y -> leibniz y x.
Proof.
unfold leibniz.
intros H P Py.
apply (H (fun z => P z -> P x)).
auto.
assumption.
Qed.
Lemma leibniz_f_equal {X Y : Type}(f : X -> Y){x x' : X} : leibniz x x' ->
leibniz (f x) (f x').
Proof.
intro H.
unfold leibniz.
intros P H1.
apply (H (fun y => P (f y))).
assumption.
Qed.
Definition Phi (a : Type) := (a -> Prop) -> Prop.
Axiom A : Type.
Axiom introA : Phi A -> A.
Axiom matchA : A -> Phi A.
Axiom beta : forall x, matchA (introA x) = x.
(* We need beta for Leibniz equality, but there is no harm in
formulating it using propositional equality (even if it does
not live in Prop), as we can always go from x = y to leibniz x y.
(The other direction only works if x = y lives in Prop.)
Lemma eq_leibniz {X : Type}{x y : X} : x = y -> leibniz x y.
Proof.
intro H.
elim H.
apply leibniz_refl.
Qed.
Lemma beta' : forall x, leibniz (matchA (introA x)) x.
Proof.
intro x.
apply (eq_leibniz (beta x)).
Qed.
Lemma introA_injective : forall p p', leibniz (introA p) (introA p') ->
leibniz p p'.
Proof.
intros.
assert (leibniz (matchA (introA p)) (matchA (introA p'))) as H1 by (apply
leibniz_f_equal; assumption).
apply (leibniz_trans (leibniz_sym (beta' p))).
apply (leibniz_trans H1).
apply (leibniz_trans (beta' p')).
apply leibniz_refl.
Qed.
Definition i {X:Type} : X -> (X -> Prop) := leibniz.
Lemma i_injective : forall X (x x' :X), leibniz (i x) (i x') -> leibniz x x'.
Proof.
intros.
assert (leibniz (i x x) (i x' x)) as H1 by (apply (leibniz_f_equal (fun y =>
y x)); assumption).
apply (H1 (fun y => y)).
apply leibniz_refl.
apply leibniz_refl.
Qed.
Definition f : (A->Prop) -> A
:= fun p => introA (i p).
Lemma f_injective : forall p p', leibniz (f p) (f p') -> leibniz p p'.
Proof.
unfold f. intros.
apply introA_injective in H. apply i_injective in H. assumption.
Qed.
Definition P0 : A -> Prop
:= fun x =>
exists (P:A->Prop), leibniz (f P) x /\ ~ P x.
Definition x0 := f P0.
Lemma bad : (P0 x0) <-> ~(P0 x0).
Proof.
split.
* intros [P [H1 H2]] H.
change x0 with (f P0) in H1.
apply f_injective in H1.
assert (P0 x0 -> P x0) by apply (leibniz_sym H1 (fun y => y x0)).
auto.
* intros.
exists P0.
split.
apply leibniz_refl.
assumption.
Qed.
Theorem worse : False.
pose bad. tauto.
Qed.
On 17/03/2020 21:43, Stefan Monnier wrote:
> According to the paper "Inductively Defined Types", Coq requires
> *strictly* positive types because non-strictly positive types can be
> used together with impredicativity to introduce a Russel-style paradox.
> More specifically, the paradox goes along the lines of
> [ I here work off of
> http://vilhelms.github.io/posts/why-must-inductive-types-be-strictly-positive/
> rather than Coquand and Paulin(-Mohring)'s paper since that paper is
> behind a paywall. ]
> - Define `Inductive A : Type = introA : ((A → Prop) → Prop) → A`.
> - Introduce an injective function `i : ∀X, X → (X → Prop)`.
> - By composing `i` and `introA` we get an injective `f : (A → Prop) → A`.
> - Define a suitable `P0 : A → Prop` and show that `P0 (f P0)` is both
> true and not.
> In the development, the definition used for `P0` would live in Type if
> it weren't for impredicativity. Which seems like "the culprit".
> But I also notice that the development defines `i` as an alias for Coq's
> equality type. But this also only works because Coq's equality type
> always lives in Prop, contrary to Agda and HoTT where it would live in
> Type (because it's an equality between objects that themselves live in
> Type). This is linked to the treatment of inductive type's indices
> which are treated "impredicatively" in Coq but not in Agda.
> If not, would that imply that non-strictly positive inductive types
> would be safe even in the presence of Prop-style impredicativity?
> Stefan
