- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Simplify after elaboration
- Date: Mon, 23 Mar 2020 22:18:34 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f42.google.com
- Ironport-phdr: 9a23:5VyTcRMwEFVrjl6hqi8l6mtUPXoX/o7sNwtQ0KIMzox0K/r8rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZHQy6Pg5oLKyhEYnLys+zyuqa+pvJYgwOiiDrMp1oKxDjjwzKsc9erpFlMb15nhnAuXxOdP5R3ng5DV2Wlhf4oMy3+cgwoGxrp/s9+psYAu3BdKMiQOkAVWV0AyUO/MTu8CL7Y06K73oYXH8Rl0MRUQfA5RD+GJz2t3mj77cv6GyhJcTzCIsMd3Gi4qNsEkK6jS4GM3s0/DiShJAqyq1cpx2lqlp0xIuGONjJZso7RbvUeJYhfUQERtxYDnUTDYa1bo9JBO0Eb75V
You don't need Ltac2 for this. The trick is to bind x to a different name in Gallina, eg,
Notation "'[SIMPL]' x" := (match x with y => ltac:(let x := eval cbv delta y in y in idtac x; let x := eval simpl in x in exact x) end)
(only parsing, at level 0, x at level 200).
On Mon, Mar 23, 2020, 21:58 Gregory Malecha <gmalecha AT gmail.com> wrote:
Hello --I'm trying to write a notation that simplifies its argument. I wrote the following:Notation "'[SIMPL]' x" := (ltac:(idtac x; let x := eval simpl in x in exact x))(only parsing, at level 0, x at level 200).
Definition foo := [SIMPL] 1 + 1.
Print foo. (* := 2 *)Unfortunately, if there is an unbound identifier in the argument of [SIMPL], I get an error message saying "x not found". What I want to do, is perform the type checking, and get the usual error message if there is an error, and otherwise, reduce the term and exact the result. I was wondering if there is some way that I could do this with Ltac2, but I haven't been able to figure it out.I know that if I'm defining a term, I can write something like:Definition foo := Eval simpl in 1 + 1.but I can't seem to do the same thing at the type level, e.g.Definition foo : Eval simpl in 1 + 1 = 1 + 1.Any pointers or suggestions would be greatly appreciated.Thanks.--gregory malecha
- [Coq-Club] Simplify after elaboration, Gregory Malecha, 03/24/2020
- Re: [Coq-Club] Simplify after elaboration, Jason Gross, 03/24/2020
