- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Hide I : True in match
- Date: Tue, 31 Mar 2020 11:28:16 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f51.google.com
- Ironport-phdr: 9a23:nlcu0RAqu0iskLyI6CssUyQJP3N1i/DPJgcQr6AfoPdwSP39oMbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERLmcAFxO+69ToXVloG80/2405zVeQRBwjSnN+BcNhKz+CfYrc4QyaR4Lb0qgk/Lq2BPfetMwnhzdHqcmh/94oG7+5s1oHcYgO4o68MVCfayRK8/V7ENVG17YVBw39XisFz4dSXK5nYYVT9LwB9BAgyA4R2jG5ms6231se1y3CTcNsrzH+htCGaSqpxzQRqtsx8pcjsw8WXZkMt11fsJrxeophg5yInRMtjMaKhOO5jFdNZfflJvG95LXnUYUIy5ZooLSeEGOLQAog==
To answer your actual question, even if perhaps not your intended one, you can pass `-noinit` to Coq and then do `Require Coq.Init.Prelude`, and then everything will need to be qualified. There isn't a good way to import just some things and not others, though there's a pull request to add this feature at https://github.com/coq/coq/pull/11820
On Mon, Mar 30, 2020 at 8:04 PM Maximilian Wuttke <s8mawutt AT stud.uni-saarland.de> wrote:
Both tricks are very nice.
Thanks
Maximilian
On 30/03/2020 11:25, Christian Doczkal wrote:
> Another possible trick is:
> Definition I := I.
> Fixpoint test (I : nat) : nat :=
> match I with
> | 0 => 0
> | S I => test I
> end.
> This way, "I" can freely be used as a pattern variable while still being
> convertible to "Logic.I"
> Best,
> Christian
> On 3/27/20 11:39 AM, Laurent Thery wrote:
>> One possible trick is :
>> match I with
>> | 0 => 0
>> | S (_ as I) => test I
>> end.
>>> match I with
>>> | 0 => 0
>>> | S I => test I
>>> end.
- [Coq-Club] Hide I : True in match, Maximilian Wuttke, 03/27/2020
- Re: [Coq-Club] Hide I : True in match, Laurent Thery, 03/27/2020
- Re: [Coq-Club] Hide I : True in match, Christian Doczkal, 03/30/2020
- Re: [Coq-Club] Hide I : True in match, Maximilian Wuttke, 03/31/2020
- Re: [Coq-Club] Hide I : True in match, Jason Gross, 03/31/2020
