- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Making Modules work
- Date: Sun, 12 Apr 2020 19:34:29 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tchajed AT mit.edu; spf=Pass smtp.mailfrom=tchajed AT mit.edu; spf=None smtp.helo=postmaster AT outgoing.mit.edu
- Ironport-phdr: 9a23:k/ueDRFuOhJyem5HPv4olp1GYnF86YWxBRYc798ds5kLTJ76r8SwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWc6iQdFxm3MQN/IazOF4jeis2206jyoMWIIlYAuD3oarRraR6ysA+Z4sIRmM5pLrs74hrPuHpBPepMkzBGP1WWyirx5I+b/Jdh/igY7+4q98dCXKnSeqUkC7FUEWJ1YCgO+MT3uEyaHkO07XwGXzBNykERX1r1qSriV5K0iRPU8/Jn0XjIOMzqC704RGb6tvY5eFrTkC4CcgUB3iTSg810grhcpUPzoh1jhYPYfdPMbacsTubmZdofAFF5cINRWihGW9PuaJYTAO0AO+keqojh4VYCsEnmCA==
I wrote an answer to this question on Stack Overflow: https://stackoverflow.com/questions/47973317/require-import-require-import.
In your particular case, the issue is the file Foo.v
is implicitly in a module called Foo
. Thus the fully qualified path to magic
is actually Foo.Foo.magic
, and after the import it’s just Foo.magic
. If you want to make just magic
work, you actually want to Require Foo
and then Import Foo.Foo
(or remove the module Foo
in Foo.v).
On Sun, Apr 12, 2020 at 7:25 PM Agnishom Chattopadhyay <agnishom AT cmi.ac.in> wrote:
Hi;I am really confused with Require, Export, Import, etc. I tried doing a Google search but I do not find any simple explanations.What I want to do is to have two files Foo and Bar:Module Foo.
Definition magic : nat := 5.
End Foo.Now, I want to be able to access magic inside Bar:Module Bar.
Require Foo.
Import Foo.
Check Foo.magic.
Fail Check magic. (* How do I make this work? *)
End Bar.What am I doing wrong?
- [Coq-Club] Making Modules work, Agnishom Chattopadhyay, 04/13/2020
- Re: [Coq-Club] Making Modules work, Tej Chajed, 04/13/2020
