- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is non-strict positivity ever okay?
- Date: Wed, 15 Apr 2020 10:54:46 +0200 (CEST)
Hi,
Well I suggest, and this is a general rule, to always write the induction principle that most fit your needs.The only issue is that now with the Fixpoint, we don't have a constructor any more. So this means with this definition, I cannot induct on the proof tree of a satisfaction or apply inversion.
Hence in your case, write down the statement of the induction/elimination principle that corresponds to
your (extended) inductive definition and then prove it with the Fixpoint definition, ie by induction on the
structure of the formula.
The inversion principle can usually be proved using the induction principle.
D.
- [Coq-Club] Is non-strict positivity ever okay?, Agnishom Chattopadhyay, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Dominique Larchey-Wendling, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Agnishom Chattopadhyay, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Adam Chlipala, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Jason -Zhong Sheng- Hu, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Jason Gross, 04/15/2020
- Re: [Coq-Club] Is non-strict positivity ever okay?, Thorsten Altenkirch, 04/15/2020
