- From: richard Dapoigny <richard.dapoigny AT univ-smb.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about Coq universes
- Date: Wed, 22 Apr 2020 17:27:10 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=richard.dapoigny AT univ-smb.fr; spf=Pass smtp.mailfrom=richard.dapoigny AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout02-ext3.partage.renater.fr
Thanks for your prompt answer. Let us consider the following test :
Universes sf2 sf1
sf0.
Constraint sf0 < sf2.
Constraint sf1 < sf2.
Parameter t1 : Type@{sf0}.
Parameter t2 : Type@{sf1}.
Parameter test : Type@{sf0} -> Prop.
Check (test t1).
(* we expect that sf0 and sf1 are two branches under sf2 and
that the following test fails *)
Check (test t2).
Le 22/04/2020 à 17:12, Gaëtan Gilbert a
écrit :
I
don't understand what you mean, perhaps you could show some
example code which does something you didn't expect or want?
Gaëtan Gilbert
On 22/04/2020 17:08, richard Dapoigny wrote:
Dear Coq Members,
We are using the Coq hierarchy of polymorphic universes which has been recently implemented by Sozeau.
We want to use it for subtyping and we expect it to be an implementation of Grothendieck universes, however it seems to be a total order. Therefore we cannot have a tree-like hierarchy.
However is it possible to ultimately have that structure?
Thanks for your answer,
Richard
*Richard Dapoigny*
/Associate Professor/ - LISTIC Laboratory
University Savoie Mont-Blanc
5, chemin de Bellevue
Po. Box 80439
Annecy-le-Vieux 74940
FRANCE
https://www.listic.univ-smb.fr/en/presentation-en/members/lecturers/richard-dapoigny-en/
/****** People who don't know history are condemned to repeat it. ******/
Richard Dapoigny
Associate Professor - LISTIC Laboratory
Po. Box 80439
FRANCE
Richard Dapoigny
Po. Box 80439
FRANCE
- [Coq-Club] Question about Coq universes, richard Dapoigny, 04/22/2020
- Re: [Coq-Club] Question about Coq universes, Gaëtan Gilbert, 04/22/2020
- Re: [Coq-Club] Question about Coq universes, richard Dapoigny, 04/22/2020
- Re: [Coq-Club] Question about Coq universes, Kenji Maillard, 04/22/2020
- Re: [Coq-Club] Question about Coq universes, Pierre Courtieu, 04/22/2020
