coq-club - Re: [Coq-Club] Locate Library syntax
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Locate Library syntax
  • Date: Tue, 28 Apr 2020 10:15:42 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua1-f43.google.com
  • Ironport-phdr: 9a23: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
Hi Jeremy,
The only explanation that I can see for your problem is that existsT
is a defined as a keyword at the point where you call Locate.
Example:
Notation "'existsT'" := 0.
Locate Library existsT.
Otherwise, this failure doesn't make any sense since existsT is a
valid identifier, and thus a valid global identifier (constr:global).
Cheers,
Théo
Le mar. 28 avr. 2020 à 08:41, Jeremy Dawson
<Jeremy.Dawson AT anu.edu.au>
a écrit :
> Hi,
> Trying to use the Locate Library command I get
> Error:
> Syntax error: [constr:global] expected after 'Library' (in [locatable]).
> I've seen this sort of gibberish before, but it's generally due to a
> recognizable syntax error. But here I can't seen what is wrong with the
> way I'm using the Locate Library command, eg
> Coq < Locate Library gen.
> gen is bound to file /home/jeremy/coq/lnt/tense-logic-in-Coq/gen.vo
> Coq < Locate Library xxx.
> Toplevel input, characters 15-18:
> > Locate Library xxx.
> Error: Unable to locate library xxx.
> these work as expected - what is happening here?
> Cheers,
> Jeremy
