- To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, "cl-isabelle-users AT lists.cam.ac.uk" <cl-isabelle-users AT lists.cam.ac.uk>
- Subject: Re: [Coq-Club] [isabelle] formal models of peripheral devices like GIC, NIC
- Date: Tue, 12 May 2020 10:23:31 +0000
- Accept-language: en-US, sv-SE
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hira AT chalmers.se; spf=None smtp.mailfrom=hira AT chalmers.se; spf=None smtp.helo=postmaster AT greyjoy.ita.chalmers.se
- Ironport-phdr: 9a23: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
Hi Abhishek,
Has someone built formal models of peripheral devices like Arm's Generic
Interrupt Controller (GIC), network interface cards that could be suitable
for proving correctness properties of software driving them (e.g. OS,
network driver)?
ARMv7-A translation lookaside buffer (TLB) based on the reference manual. I have then soundly
abstracted this model using data refinement to extract an abstract model that is easier to reason about
from software point of view. Using the abstract TLB+page tables as the memory model, I have
further developed a logic for reasoning about low-level programs in the presence of cached
address translation, and have with ease extracted invariants for user and kernel level code,
including context switch and page table manipulations.
Here are some links:
Publications:
in chronological order
1. Reasoning about Translation Lookaside Buffers, LPAR17.
2. Program verification in the presence of cached address translation, ITP18
3. Formal Reasoning Under Cached Address Translation, JAR20
PhD thesis:
Ongoing work: to develop a formally verified TLB-aware compiler.
Isabelle Theories: https://github.com/SEL4PROJ/tlb
Hope this helps,
Thanks
Hira
On 11 May 2020, at 22:27, Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
network driver)?
I'd be grateful for pointers to such work. The models need not be in
Coq/Isabelle, as long as there is a plausible way to convert them to
Coq/Isabelle models that describe the behavior of such devices.
Thanks,
-- Abhishek
http://www.cs.cornell.edu/~aa755/
- [Coq-Club] formal models of peripheral devices like GIC, NIC, Abhishek Anand, 05/11/2020
- RE: [Coq-Club] formal models of peripheral devices like GIC, NIC, Fernandez, Matthew, 05/11/2020
- Re: [Coq-Club] formal models of peripheral devices like GIC, NIC, Larry Lee, 05/11/2020
- Re: [Coq-Club] [isabelle] formal models of peripheral devices like GIC, NIC, Hira Taqdees Syeda, 05/12/2020
