coq-club - Re: [Coq-Club] (Computationally) Efficient Finite Maps
  • From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] (Computationally) Efficient Finite Maps
  • Date: Thu, 14 May 2020 18:27:23 +0200
  • Autocrypt: addr=pierre-marie.pedrot AT inria.fr; prefer-encrypt=mutual; keydata= mQINBFOFpSQBEACyDotTWHydRK+7nzdk+ULrBszrG8Eu7J59+eogMOIOQYKw/joFiTOHnJgG vUzt//PqMURC7tZ72teZHeyLKHwr3a9oOC4W36Wrt4jVGvAnYk60hF20i921ljIN8aj41UYz t+8vgsqgpTCNbcgxhhgXSQ+9n/OZs1yoy6kgIE378HsIhGoGTQxmwdz2k0Aic/qun2Z4CO9v zjTjkUYMJxs4XwVsprMkO/a6qVBkNtEjbwVDJS5d7qzfph2DHJXFyUOPc1GudPI+VW2Abi4A 2US/ycyGMUTYRVaUDUF/GqfqmYgUj4vFvANdB3Roa3XDVxAlkYcNuUqtcpQi9yoU6t+Agobp nqcn+WrtOwrJtvEh3KaaQvI4Yudz3pEmP9KL2VYenUQLuDqVL4KgdCPcAZmpkSC7KCm8Ns2v y69zHasNsPD9YiIXCgpGNZEEUjrG8Si+ej3/3MTqTBQqpSzqTagtGhGANrjEgHj6zdh+plby k/bCYHjX4oDPJZQx6GjmtGPandUAD+SImEwS6WMyCKtUSKJtqD+DVNWiwKAK3+CNxDW/DbRS /N2ACdtItJhFmPAb9Nxs6O27xyPCse4n9fMCT5pLQpDfMmkOQsjr1kCWiOWgjIgfOG64HrxQ Vcjg6mf9EEGVi4kpMhl6RzZ7wsg+ff3w/5NR1e1HX9yj/UbsLwARAQABtDNQaWVycmUtTWFy aWUgUMOpZHJvdCA8cGllcnJlLW1hcmllLnBlZHJvdEBpbnJpYS5mcj6JAj4EEwECACgFAlOF pSQCGwMFCRLMAwAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEHkiwB/Zujx745sP/3JA gDdlat/mjqxgpC30Jy5Rnkgblxo/qnEmmhPxSQJKt77JaaDgRfsTrJZcO1K9LN6aLs8dPo26 V29TSt0UJhw5bQcTqi/wlD/ZfQ3I69gn9x6ln3T/7TV/g0tyObbzPYQLsi6p8wgJzO1F3Dr2 9XjEfB2jVs7ancTKbE+5yvwN0v3VCrtG5cFpAdkrMtZzXbXMAxRa7HueUjtxm/ls5zqbwTZ6 1tmJlSJJS+rL43InCxDFRbPO4YzV3z7+sEw/Kpn3HwVQz6y3aDQWqQlq/vF8r0p+3E3CB+h/ h6coMySbpwHZAAMsu9KpQBqGpbAjI5RXvcNJD+7MCqT5LYy/QmULqVaLS7zaspcZc2V2CW1w 4LaZtlMjt4gedGvd/UICuy1pw1GdR3YRlUCQGKnzVp8Cw1Bsd1SbZu0DT/DOt3DHyZLliENu P6PRPQT+Rmj21mDpj+bLJliIpRWQ99/cFA6mmKv7qYk49xWsUL0YxcGabGIObBbMpFoq+Coj 8Gmm10706NrJuhYJMxdxHQNbiV8eYnC6jKnL0F3BPeEloSpw0saq/8PVU7eTwvkrOBTVfiwa UFe7HLFDo6SaRoXJAeBa22ADM4bTQCrf856BMT/4BjHdSUAj4Sq1j1QUHVTWWRVsnNH8Nz10 /n2x8sxQIf8yVX4aN/Km/uz7Xq14hL6suQINBFOFpSQBEADMsZKO9fPtbmyMlS5YQl3B+p5E 17sEJAHSNGA4rfx7Uxij1H1PnTZ0kHhngrhEG1wzv2+1aORCg31Jqrwf//XPbcv6QL4CinD7 QUpbMdrZFo296AkAjuhO8J0LvB8CY3GY6n/G3njy9ISmemEH3dAzOM87Wt0En1dcSYJxdfM2 fmWq6ghlmcQA6A6g1vJ0iKnFcvh/IXHBm1/dtVSOj+2+S4/PLALMCUzugFQLVAKiv7pkdxPz KGxMMEnQuLXjoFivXV6i3q9+0FVVo2t9LfD1EzTNoKwx4866nVnVMU9myd6IS03lKAREmHhb YRKJt+dlmJoqttVczsruFa1SRmzhpp5O2jFWzR0C+SD23s70PXaZ4wcn4TzQKL+tGMRqELLF XepqWcmKnROvX+agmeZK1UxhaIGI0JpPtZHsNGNoU1dbzUE+opzHP5Lpouc5Te+MkXe4wSM6 WrfyTRqUfVr7CeaSozkX/AfgubNnNYmi8RduUjUBjukMEsRchirbyCh1397xK90HDpiiqPy/ PLaUx/sp2vp0TSxGPFtl9CmuSOPVi0HQI51SrnckMA/zQJu6AZyFkbb7fpUi/cPds7AVCLjd mNkLOe77sZ+/D3YKXiHujrpncau+NaQ2SKMrqcRocAeogbd+VV3DFGRgHereAZwHD87ruHeg jEO92QRw/QARAQABiQIlBBgBAgAPBQJThaUkAhsMBQkSzAMAAAoJEHkiwB/Zujx7eSsQAJnw yYs/yiYjwzYdlmGQP1fuG0RG6DwHXZDti9etXRhjgOMvE4+TKqSeM9gXCxdGE7M2aKV+PJvi twb4FRLBOl9YwlHTiV5UIJpcbJv+zvdNSDrlqSSln1Qfqq7HJUvDwSKcY8316pVuF5Q9gknX P/gRG4O8e/fBXuSiL08cDudnkbhSm6zb+VGaewivO0FuuCX4RpYtF4EULbCKof7SSCK3/WWl roX6H3S6dNo/3cUGahj7FfTaQMwHH34P6wGWtJCh7vhaxQ5QdXjj8ZkJfcE03uo+GbF7/xmo g5wxtsFUWhs5G0P534BmahBBKsINIyExt6JYASYL/oouC9c+AOjc3bON7Ae1jeHgx3BSSUju 81x+5MrXAqrLhJ6xDsQpATL7qDcBEHBodo0xlAIgb71qeIU5gZUOw/43eJOnexDFs4VWMthJ z2ot6WdRzYEKt75nuCZqaaUEM+MvOGNZZRM3Dkbqw3Jik1X+lOjc/OgUs+Xn9oaIylA1nojO 9E31ulGmniydilLd+4Vd+WQn0ZEwy75EzDTl0Ne/j8nvLyzeYIWbt5/06mR2L87DIEXmXkAM mwfFXNzzX9gVX8m7owb4CPTf5DCDrguwNdvcPePy81w+fXM7c0Dq+5hzPvh5MRruEDOfqaZw HXQ4ZkGmhsCD6dMF2cKX+EqLjopA136U
On 14/05/2020 17:04, Xavier Leroy wrote:
> The problem I see here is that most efficient data structures I can
> think of are not freely generated by constructors, but have richer
> structural invariants that need to be maintained using predicates and
> proof terms.  (For example, Frédéric Besson mentioned Patricia trees.  I
> played with them in Coq a while ago and they have plenty of structural
> invariants.)  So, this phenomenon of proof terms growing linearly with
> the number of operations performed seems hard to avoid.
> It could be that there is a fundamental tension between 1) having
> efficient data structures, and 2) building valid proof terms.  That
> would make me sad.
If your well-formedness predicate is decidable, you can always replace
it by a proof that the computational boolean version is equal to true.
Now you're trading proof size for computation time, which may be worse,
or not, if you proofs are similarly efficient.
So is life in the world of proofs-as-programs, and only people
brainwashed by realizability believe that substanceless proofs float
around in a space of ethereal truth.
PMP
Attachment: signature.asc
Description: OpenPGP digital signature
