Re: [Coq-Club] [isabelle] Prior work on proof assistant performance / optimization
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>, lean-user <lean-user AT googlegroups.com>, cl-isabelle-users AT lists.cam.ac.uk
- Subject: Re: [Coq-Club] [isabelle] Prior work on proof assistant performance / optimization
- Date: Thu, 14 May 2020 13:30:17 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=konrad.slind AT gmail.com; spf=Pass smtp.mailfrom=konrad.slind AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f46.google.com
- Ironport-phdr: 9a23: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
As Larry said, there has been a lot of work on this over the years. A few references off the top of my head (slightly HOL-centric)
Related to this is work on sound interfaces to external tools, also an enduring topic:
On Fri, May 8, 2020 at 4:08 AM Jason Gross <jasongross9 AT gmail.com> wrote:
I'm in the process of writing my thesis on proof assistant performance
bottlenecks (with a focus on Coq). I'm having some trouble finding prior
work on performance engineering and/or benchmarking of proof assistants
(other than the paper on the Lean tactic language (
https://leanprover.github.io/papers/tactic.pdf)), and figured I'd reach out
to these lists.
Does anyone have references for prior work on performance analysis or
engineering of proof assistants or dependently typed languages? (Failing
that, I'd also be interested in papers about compile-time performance of
compilers.)
Thanks,
Jason
- [Coq-Club] Prior work on proof assistant performance / optimization, Jason Gross, 05/08/2020
- Re: [Coq-Club] Prior work on proof assistant performance / optimization, Stefan Monnier, 05/08/2020
- Re: [Coq-Club] [Agda] Prior work on proof assistant performance / optimization, András Kovács, 05/08/2020
- Re: [Coq-Club] [Agda] Prior work on proof assistant performance / optimization, Stefan Monnier, 05/12/2020
- Re: [Coq-Club] [Agda] Prior work on proof assistant performance / optimization, András Kovács, 05/12/2020
- Re: [Coq-Club] [Agda] Prior work on proof assistant performance / optimization, Wolfram Kahl, 05/12/2020
- Re: [Coq-Club] [Agda] Prior work on proof assistant performance / optimization, Jason Gross, 05/14/2020
- Re: [Coq-Club] [isabelle] Prior work on proof assistant performance / optimization, Lawrence Paulson, 05/08/2020
- Re: [Coq-Club] [isabelle] Prior work on proof assistant performance / optimization, Konrad Slind, 05/14/2020
