coq-club - Re: [Coq-Club] nth element of a vector
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] nth element of a vector
  • Date: Sat, 23 May 2020 03:48:17 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tadeusz.litak AT gmail.com; spf=Pass smtp.mailfrom=tadeusz.litak AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f48.google.com
  • Ironport-phdr: 9a23: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
Hi Fritjof,
this discussion has been going on for a few days already and it seems that nobody has suggested to use ssreflect vectors (n.-tuple) instead.
In my limited experience, this has so far proved the most usable solution. All the other ones sooner or later seem destined to brutally remind one of idiosyncrasies of dependent pattern matching in Coq.
In particular, the function you're looking for seems directly available.
Do you have important reasons to stick with Coq.Vectors.Vector?
Best,
t.
On 20.05.20 17:15, Fritjof Bornebusch wrote:
Hi there,
I'm looking for a function that iterates over a vector -
https://coq.inria.fr/library/Coq.Vectors.Vector.html - and returns
the Zth element, like the nth element of a list.
The library function only dealy with the Fin.t type, but I need Z.
Does anyone has a suggestion or hint?
Best Regards,
--f.
