- From: "jonikelee AT gmail.com" <jonikelee AT gmail.com>
- To: Christian Doczkal <christian.doczkal AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How do I simplify a particular redex exactly once?
- Date: Thu, 28 May 2020 15:10:38 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt1-f195.google.com
- Ironport-phdr: 9a23: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
One wonders, if we all have developed these toolboxes of tricks to get
single-step reductions because Coq doesn't provide them: perhaps Coq
should provide them?
Attached are some single-step beta and zeta reduction term-manipulating
tactics, along with a related pattern-based subst tactic. I haven't
tested these since Coq 8.6.
Jonathan
On Thu, 28 May 2020 20:40:09 +0200
Christian Doczkal <christian.doczkal AT inria.fr> wrote:
> If one only runs into the need for blocking reduction every once in a
> while, one can also do:
> Definition locked {X} (x:X) := x.
> Lemma lock {X} (x:X) : x = locked x. Proof. reflexivity. Qed.
> Opaque locked.
> Goal forall {A} (f g h: @Formula A) x,
> exists y, eval (FAnd (FOr f g) h) x = y.
> Proof.
> eexists.
> rewrite (lock (FOr _ _)); simpl; rewrite <- lock.
> Abort.
> (Or: "rewrite [FOr _ _]lock /= -lock" when using the ssreflect
> rewrite)
> Best,
> Christian
> On 5/28/20 6:30 PM, Clément Pit-Claudel wrote:
> > On 27/05/2020 11.55, Agnishom Chattopadhyay wrote:
> >> Now, let's say I have a proof and I have an expression e = (FAnd
> >> (FOr f g) h), and I am trying to simplify (eval e x). If I simply
> >> suggest `simpl.`, Coq simplifies it all the way down. How can I
> >> control simpl so that only the first FAnd is simplified but the
> >> FOr is not?
> >> Currently, I am using "replace ... with ... " but this requires me
> >> to type out all the details, which is very painful. The actual
> >> formula and eval that I have are more complex than this.
> >> Another option seems to be `remember (FOr f g) as z.` and then
> >> doing `simpl.`, but this is also not very nice since I have to
> >> copy large chunks of the expression to my proof.
> > This is a common problem with recursive functions in Coq. Two
> > tricks I like:
> > 1. Define a set of equations for your function, which you can then
> > use to rewrite:
> > Open Scope bool_scope.
> > Lemma eval_FAnd {A : Type} (f g : @Formula A) (x : A) :
> > eval (FAnd f g) x = (eval f x) && (eval g x).
> > (* more equations here *)
> > Proof.
> > eexists.
> > rewrite eval_FAnd.
> > Abort.
> > You can also look at the Equation plug-ins — I keep hearing good
> > things about it. This solution quickly gets old quickly if you
> > have many cases, though, because you need to define the lemmas.
> > Also, the rewrites can get costly.
> > 2. Define an unfolding function, which does one step of unfolding
> > for you:
> > Definition eval1 {A : Type} (f : @Formula A) (x : A) : bool
> > := match f with
> > | FAtomic f => f x
> > | FAnd f g => (eval f x) && (eval g x)
> > | FOr f g => (eval f x) || (eval g x)
> > end.
> > Proof.
> > eexists.
> > change (eval ?f ?x) with (eval1 f x). (* No need to
> > rewrite, even! *) cbv [eval1].
> > Abort.
> > Of course, it's still annoying to have to duplicate the
> > function, so you can automatically define it:
> > Ltac unfold_once expr param :=
> > pose expr as result;
> > destruct param; cbn in result;
> > lazymatch goal with
> > | [ _ := ?result |- _ ] => exact result
> > end.
> > Definition eval1_auto' {A : Type} (f : @Formula A) (x : A) :
> > bool. unfold_once (eval f x) f.
> > Defined.
> > Proof.
> > eexists.
> > change (eval ?f ?x) with (eval1_auto' f x).
> > cbv [eval1_auto'].
> > Abort.
> > Here's a slightly cleaner definition, too:
> > Definition eval1_auto {A : Type} (f : @Formula A) (x : A) :
> > bool. let r := constr:(ltac:(unfold_once (eval f x) f)) in
> > let r := eval cbv zeta in r in
> > exact r.
> > Defined.
(*********************************************************************** Single Step beta and zeta reduction, and associated substitution tactics ***********************************************************************) Ltac subst_binder x c T := (*Do the substitution "T[x := c]" without any other reduction. Requires that x be an intropattern and T a constr_with_bindings that needs a binding for x - these are the types one gets when matching T under a binder for x*) (*How it works: the constr for the lazymatch uses let-ins that are then unfolded within the tactic-in-term by delta reduction, making the let-in bindings be unused by the resulting proof term (z). The lazymatch can then ignore (via underscores) the unused let-in binders and pick out the result (T'), which is then a normal constr instead of a constr_with_bindings.*) let r := fresh in lazymatch constr: (let x := c in let r := T in ltac:(let z := (eval cbv delta [x r] in r) in exact z)) with (let _ := _ in let _ := _ in ?T') => T' end. Ltac zeta1 term := (*Do a single zeta reduction step on a let-in term, such that nothing else within the term is reduced*) lazymatch term with | (let x := ?c in ?T) => subst_binder x c T | _ => fail "zeta1: There is no outer let-in in" term end. Ltac beta1 term := (*Do a single beta reduction step on a fun application term, such that nothing else within the term is reduced*) lazymatch term with | ((fun x => ?T) ?c) => subst_binder x c T | (?F ?A) => let F' := beta1 F in constr:(F' A) | _ => fail "beta1: There is no fun application at the head of" term end. Ltac subarg_beta1 c T := (*T must be a function application, into which c is substituted for the outermost arg, and then a single beta reduction is done. The primary purpose is when T is the result of eval pattern, making some common subterm into its outermost arg, and then c is substituted for that subterm*) lazymatch T with (?F _) => let T' := constr:(F c) in beta1 T' end. Ltac subst_in p c T := (*Do the substitution "T[p := c]" without any other reduction, and with p and T being normal constrs, with all of p free in T*) (*Unfortunately, we can't pass a position selector to eval pattern unless this is a Tactic Notation, but a Tactic Notation can't return a constr. If a position is needed, replicate the eval-pattern-subarg_beta1 term with the position inserted into the eval-pattern part.*) let T' := (eval pattern p in T) in subarg_beta1 c T'. (*** Unit Tests ***) Goal True. Proof. let t := constr:(let a := 1 in let b := 2 in a + b) in let t' := zeta1 t in constr_eq t' (let b := 2 in 1 + b). let t := constr:((fun x => x) (let a := 1 in a)) in tryif (let t' := zeta1 t in idtac t') then fail "zeta1 should have failed on" t else idtac. let t := constr:(let a := (let b := 1 in b) in a + 1) in let t' := zeta1 t in constr_eq t' ((let b := 1 in b) + 1). let t := constr:(let a := 1 in (fun x => x + a) 3) in let t' := zeta1 t in constr_eq t' ((fun x => x + 1) 3). let t := constr:(let a := Type in a) in let t' := zeta1 t in constr_eq t' Type. let t := constr:(id (let a := 1 in a)) in tryif (let t' := zeta1 t in idtac t') then fail "zeta1 should have failed on" t else idtac. let t := constr:((fun x y => x + y) 1 2) in let t' := beta1 t in constr_eq t' ((fun y => 1 + y) 2). let t := constr:((fun x => x) (fun y => 1 + y) 2) in let t' := beta1 t in constr_eq t' ((fun y => 1 + y) 2). let t := constr:((fun x => let y := 1 in x + y) 2) in let t' := beta1 t in constr_eq t' (let y := 1 in 2 + y). let t := constr:(let a := 1 in ((fun x => a + x) 2)) in tryif (let t' := beta1 t in idtac t') then fail "beta1 should have failed on" t else idtac. let t := constr:((id (fun x => x)) 1) in tryif (let t' := beta1 t in idtac t') then fail "beta1 should have failed on " t else idtac. let t := constr:((fun x => x) Type) in let t' := beta1 t in constr_eq t' Type. pose proof 0 as a. let t := constr:((fun c => let b := (a + 1) in c + a + b + a) (a + 2)) in let t' := subst_in a (a + 3) t in constr_eq t' ((fun c => let b := (a + 3 + 1) in c + (a + 3) + b + (a + 3)) ((a + 3) + 2)); let t'' := subst_in (a + 3) 42 t' in constr_eq t'' ((fun c => let b := (42 + 1) in c + 42 + b + 42) (42 + 2)). exact I. Qed.
- [Coq-Club] How do I simplify a particular redex exactly once?, Agnishom Chattopadhyay, 05/27/2020
- Re: [Coq-Club] How do I simplify a particular redex exactly once?, jonikelee AT gmail.com, 05/27/2020
- Re: [Coq-Club] How do I simplify a particular redex exactly once?, Jan-Oliver Kaiser, 05/28/2020
- Re: [Coq-Club] How do I simplify a particular redex exactly once?, Clément Pit-Claudel, 05/28/2020
- Re: [Coq-Club] How do I simplify a particular redex exactly once?, Christian Doczkal, 05/28/2020
- Re: [Coq-Club] How do I simplify a particular redex exactly once?, jonikelee AT gmail.com, 05/28/2020
