- From: "jonikelee AT gmail.com" <jonikelee AT gmail.com>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] what does "0 calls" imply in Ltac profile output?
- Date: Sat, 25 Jul 2020 22:29:38 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt1-f171.google.com
- Ironport-phdr: 9a23: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
Sorry. I wasn't trying to argue one way or the other. I was just
expressing some surprise about that way of measuring. As you know,
it's almost never the case that one wants a tactic that evaluates as a
pure tactic expression, although in most usages it doesn't matter. So I
have no problem using "count 0" as an indicator that I need to insert
"idtac;" at the beginning of that tactic definition.
But, I still don't know what the local column is about. I now have
seen tests where it can't possibly mean the time spent in the tactic
excluding its callees, because then the local column would not sum to
well over 100%, which it can do. It does seem that local is always <=
total, but sometimes it is just slightly <, and other times it is very
much <.
On Sat, 25 Jul 2020 21:55:03 -0400
Jason Gross <jasongross9 AT gmail.com> wrote:
> > If as a
> tactic expression it is evaluated and not counted, why then isn't its
> evaulated form counted directly by its parent tactics in the call
> chain?
> Because the time is still spent in that tactic. It seems obvious to
> me that the time spent in expression evaluation should be counted as
> in that tactic; to say otherwise seems misleading to me.
> The real question is, do we count the calls in expression evaluation?
> If we do then a tactic defined as `idtac` will accumulate two calls:
> once when it's evaluated trivially to idtac, and again when it's run.
> But if we don't include the calls in expression evaluation, then we
> end up with the problem you've encountered, where some tactics have
> no calls.
> On Sat, Jul 25, 2020, 21:36 jonikelee AT gmail.com <jonikelee AT gmail.com>
> wrote:
> > The 'use_node' tactic is a tactic expression (no ';' sequence), so
> > I can understand why (but did not anticipate that) its count would
> > be 0 according to the info you provided. But it is still counted
> > with respect to local and total timing, according to the output.
> > If as a tactic expression it is evaluated and not counted, why then
> > isn't its evaulated form counted directly by its parent tactics in
> > the call chain?
> > Regardless, I will stick an "idtac;" at the start of each 0-counted
> > tactic that I want correct call counts for (which is all of them).
> > On Sat, 25 Jul 2020 20:34:21 -0400
> > > What's the definition of `use_node`? Note that the profiler does
> > > not count calls to tactics which are run during tactic expression
> > > evaluation, only during tactic running time. Consider, for
> > > example: Ltac foo _ := idtac.
> > > Ltac bar := let __ := match goal with _ => foo () end in
> > > idtac.
> > > Ltac baz := bar.
> > > Ltac qux := idtac; baz.
> > > Goal True.
> > > Set Ltac Profiling.
> > > qux.
> > > Show Ltac Profile CutOff 0.
> > > (* total time: 0.000s
> > > tactic local total calls
> > > max
> > > ─qux ----------------------------------- 32.8% 100.0% 1
> > > 0.000s ─baz ----------------------------------- 12.1% 65.5%
> > > 0 0.000s ─bar ----------------------------------- 50.0% 55.2%
> > > 1 0.000s ─foo ----------------------------------- 5.2%
> > > 5.2% 0 0.000s
> > > max
> > > 0.000s ├─baz --------------------------------- 12.1% 65.5%
> > > 0 0.000s │└bar --------------------------------- 48.3% 53.4%
> > > 0 0.000s │└foo --------------------------------- 5.2% 5.2%
> > > 0 0.000s └─bar --------------------------------- 1.7%
> > > 1.7% 1 0.000s
> > > The way to interpret this is that, during tactic expression
> > > evaluation phase, baz calls bar which calls foo, and none of
> > > these are counted as calls (if they were, we'd end up
> > > double-counting almost all tactics). After tactic expression
> > > evaluation phase, the remaining tactic to run is "idtac" under
> > > "bar", so we get "bar" as a direct descendent of "qux" with one
> > > call.
> > > On Sat, Jul 25, 2020 at 2:46 PM jonikelee AT gmail.com
> > > <jonikelee AT gmail.com> wrote:
> > > > I am perhaps not interpreting Ltac Profiling output correctly,
> > > > but having 0 for calls below seems like it must be a bug, since
> > > > either use_node must have been called at least once, or it must
> > > > have calls within it to have a very different local vs. total
> > > > percentage:
> > > > max
> > > > ─tac ----------------------------------- 0.6% 82.2% 41833
> > > > 11.316s ─force refine (uconstr) by (tactic1) --- 0.0% 57.5%
> > > > 148 11.332s ─use_node ------------------------------ 0.0%
> > > > 56.4% 0 23.650s ...
> > > > Is this a bug? If not, what is the proper interpreation of the
> > > > calls column? Or, for that matter, all columns?
> > > > My probably incorrect interpretation is that "local" refers to
> > > > the particular tactic excluding any others it calls, while
> > > > "total" includes others it calls. And calls is the total number
> > > > of times it runs. And max is the maximal amount of time of any
> > > > single call, including sub calls. This makes sense except for
> > > > calls = 0 cases, of which I have several. My alternate
> > > > interpretation of calls would be that it is the total number of
> > > > calls the tactic makes (subcalls), but that cannot be 0 unless
> > > > that tactic's local and total are the same (or very close).
> > > > I'm also assuming that the top "tac" line is the total for all
> > > > tactics.
> > > > Note that the refman is silent about the interpretation of the
> > > > output, but its examples do show cases where calls=0. And in
> > > > those cases local and total are very close (so perhaps my
> > > > alternate interpretation of calls is correct, and the
> > > > total-local difference is just the Ltac call overhead of the
> > > > tactic itself?).
> > > > BTW: this is in the tagged 8.12 build as of yesterday, where
> > > > supposedly the longstanding Ltac Profiling shortcoming vs.
> > > > multi-success backtracking tactics has been fixed. I had
> > > > previously not paid close attention to anomalies in the Ltac
> > > > Profiling output because of that shortcoming.
> > > > Thanks,
> > > > Jonathan
- [Coq-Club] what does "0 calls" imply in Ltac profile output?, jonikelee AT gmail.com, 07/25/2020
- Re: [Coq-Club] what does "0 calls" imply in Ltac profile output?, Jason Gross, 07/26/2020
- Re: [Coq-Club] what does "0 calls" imply in Ltac profile output?, jonikelee AT gmail.com, 07/26/2020
