coq-club - Re: [Coq-Club] Recursive Notation in Coq
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Recursive Notation in Coq
  • Date: Tue, 28 Jul 2020 15:14:51 +0200 (CEST)
Thanks for the suggestion but can you do it
when the type X is not uniform? I mean the
type of red is actually
red {X Y : Type} : phi X -> phi Y -> Prop where phi : Type -> Type
D.
----- Mail original -----
> De: "Maximilian Wuttke" <mwuttke97 AT posteo.de>
> À: "coq-club" <coq-club AT inria.fr>
> Envoyé: Mardi 28 Juillet 2020 15:08:43
> Objet: Re: [Coq-Club] Recursive Notation in Coq
> Hi Club,
> In addition to the solution I posted on Discourse [1], here's an
> implementation of Adam's idea:
> Fixpoint chainToProp {X : Type} (R : X->X->Prop) (xs : list X) : Prop :=
> match xs with
> | nil => True
> | x :: xs =>
> match xs with
> | nil => True
> | y :: nil => R x y
> | y :: _ => R x y /\ chainToProp R xs
> end
> end.
> Notation "'chain' xs 'endchain'" := (ltac:(let x := eval cbv
> [chainToProp] in (chainToProp le xs) in exact x)) (only parsing).
> Check chain [1;2;3;4] endchain.
> (* 1 <= 2 /\ 2 <= 3 /\ 3 <= 4 *)
> (* : Prop *)
> [1]: <https://coq.discourse.group/t/notation-for-inequality-chain/979/2>
> On 28/07/2020 14:44, Adam Chlipala wrote:
>> My guess is that (1) you may need to add some kind of brackets around
>> the notation, and (2) you may need to build a Gallina list of the
>> different elements and then apply a Gallina function that checks
>> relatedness of adjacent elements.  There is indeed a built-in notation
>> facility for variable-length forms, but I don't think it allows
>> constructing subterms out of adjacent parts of the original argument
>> list, and it doesn't allow referencing the same notation recursively in
>> the expansion.
>> On 7/28/20 8:39 AM, Dominique Larchey-Wendling wrote:
>>> Dear all,
>>> If a notations wizard could help me at defining
>>> the following recursive notation in Coq, I would
>>> be very grateful.
>>> x ⪯ y ⪯ .. ⪯ z := red x y /\ y ⪯ .. ⪯ z
>>> where red : _ -> _ -> Prop
>>> ie
>>> a ⪯ b ⪯ c ⪯ d would be (red a b) /\ (red b c /\ red c d).
>>> Sequences must have length >=2 (otherwise they would be meaningless)
>>> Thank you very much for some insights,
>>> Dominique
