- From: Gregory Malecha <gregory AT bedrocksystems.com>
- To: coq-club AT inria.fr
- Cc: "jonikelee AT gmail.com" <jonikelee AT gmail.com>
- Subject: Re: [Coq-Club] Ltac2 Performance Question
- Date: Sun, 2 Aug 2020 10:44:02 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gregory AT bedrocksystems.com; spf=None smtp.mailfrom=gregory AT bedrocksystems.com; spf=None smtp.helo=postmaster AT mail-pg1-f180.google.com
- Ironport-phdr: 9a23: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
Thanks Jason and Jonathan!
I'm still on 8.11.2, it looks like I need to upgrade to 8.12 to get more array functions.
Regarding the two suggestions,
1. In the AST, references to globals are leaf nodes (modulo universe instances), so I had expected this to happen anyways without any manual intervention on my part. I do have other cases with universe polymorphism and in those cases I definitely can not pull that trick without building a sub-optimal proof at the universe level. I could do the comparisons manually, but it seems that there are no equality tests on types like [inductive] and [constructor]. I opened an issue for that: https://github.com/coq/coq/issues/12786
That said, this is great because it actually gives me a way to bind the universe [instance], unfortunately, there seem to be no accessors on [instance]..so it might not help as much as I would like.
2. I want to check that the head constant is [and], otherwise I'd be returning an incorrect proof term. Again, I am probably mistaken, but I thought that lazy_match was implemented using Constr.Unsafe. This should definitely be possible when the pattern is linear, and might also be true when the pattern is non-linear, though there would be some side-conditions to check.
On Sun, Aug 2, 2020 at 12:14 AM Jason Gross <jasongross9 AT gmail.com> wrote:
> constructing the array is quite annoying, maybe there is notation that I missed?I generally use `Array.of_list` with the notation `[x; y; z]` (or maybe it's `[|x; y; z|]`?, I can't quite recall),which is a tiny bit more expensive, but much more compact.> (* Ltac2 (Unsafe) implementation *)I would suggest two changes:1. pass in `constr:(I)` and `'conj` at the top level (and pass them down recursively) so you only construct them once rather than at every node2. Use `match Constr.Unsafe.kind p with` rather than `lazy_match!`. It's significantly more opaque and less robust to mis-matches (generally, e.g., I'll skip the check that the head constr is and, skip the array length checks, etc), but I think it's significantly faster.On Sat, Aug 1, 2020 at 11:57 PM Gregory Malecha <gregory AT bedrocksystems.com> wrote:The unsafe version of the tactic is included below, constructing the array is quite annoying, maybe there is notation that I missed? Certainly adding the [check] here is pretty expensive.I filed an issue here which contains the full text (also included below): https://github.com/coq/coq/issues/12785Returning to the earlier question, I get back a decent amount of performance in my original tactic by using [@conj p q l r] rather than [conj l r] in both the Ltac and the Ltac2 case.My latest figures show less performance loss than I originally measured (2x instead of 3x), there might have been too much jitter in my tests. The numbers below are averages of 10 fresh runs.(* Ltac2 implementation *)
Ltac2 rec build2 p :=
lazy_match! p with
| True => constr:(I)
| ?p /\ ?q =>
let l := build2 p in
let r := build2 q in
constr:(@conj $p $q $l $r)
end.
Ltac2 rec build2_unsafe p :=
lazy_match! p with
| True => constr:(I)
| ?p /\ ?q =>
let l := build2_unsafe p in
let r := build2_unsafe q in
let ary := Array.make 4 p in
let _ := Array.set ary 1 q in
let _ := Array.set ary 2 l in
let _ := Array.set ary 3 r in
Unsafe.make (Unsafe.App 'conj ary)
end.
(* Ltac2 (Unsafe-Check) implementation *)
Ltac2 rec build2_unsafe_check p :=
lazy_match! p with
| True => constr:(I)
| ?p /\ ?q =>
let l := build2_unsafe_check p in
let r := build2_unsafe_check q in
match Unsafe.check (Unsafe.make (Unsafe.App 'conj ary)) with
| Val v => v
| Err e => Control.throw e
end
end.
(* Ltac implementation *)
Ltac build_it p k :=
lazymatch p with
| True => k constr:(I)
| ?p /\ ?q => build_it p ltac:(fun P => build_it q ltac:(fun Q => k constr:(@conj p q P Q)))
end.Fixpoint build_goal (n : nat) : Prop :=
match n with
| 0 => True
| S n => build_goal n /\ build_goal n
end.
Goal build_goal 10.
simpl.
Time Control.enter (fun () =>
let g := Control.goal () in
let pf := build2 g in
exact $pf).(** ~0.2241s *)
Undo.
let pf := build2_unsafe g in
exact $pf).(** ~0.1444s *)Time Control.enter (fun () =>
let pf := build2_unsafe_check g in
exact $pf).(** ~0.2307s *)Undo.
Time repeat constructor.(** ~0.1658s *)
Undo.
Time ltac1:(match goal with
| |- ?G => build_it G ltac:(fun p => exact p)
end).(** ~0.0939s *)
Qed.On Sat, 1 Aug 2020 13:16:32 -0400
> Thanks for pointing that out. It inspired me to look at the resulting
> code. I get the following:
> build : constr -> constr
> build :=
> fun x =>
> let rec build :=
> fun p =>
> let m :=
> [Pattern.MatchPattern, pattern:(True), (fun _ => fun _ =>
> constr:(I)); Pattern.MatchPattern, pattern:(and ?p ?q),
> (fun _ =>
> fun p => let q := Array.get p 1 with p := Array.get p 0 in
> let l := build p in let r := build q in constr:(@conj _ _ _ _))] with
> t := p in
> Pattern.lazy_match0 t m in
> build x
> I assume that the `_`s in the constr: are printing artifacts.
> You are right, building the term with Unsafe gets me performance on
> par with Ltac. It seems like this would be a natural implementation
> of constr, and for some reason I thought that I had read that it was
> in the manual, but I must be mistaken.
Grregory,
What does the Unsafe-using version of your example look like?
--Gregory Malecha
Mail: gregory AT bedrocksystems.com
BedRock
Systems Inc
FORMALLY SECURED COMPUTING
UNBREAKABLE FOUNDATION FOR
Gregory Malecha
BedRock
Systems Inc
FOR
- [Coq-Club] Ltac2 Performance Question, Gregory Malecha, 08/01/2020
- Re: [Coq-Club] Ltac2 Performance Question, Jason Gross, 08/01/2020
- Re: [Coq-Club] Ltac2 Performance Question, Gregory Malecha, 08/01/2020
- Re: [Coq-Club] Ltac2 Performance Question, jonikelee AT gmail.com, 08/01/2020
- Re: [Coq-Club] Ltac2 Performance Question, Gregory Malecha, 08/02/2020
- Re: [Coq-Club] Ltac2 Performance Question, Jason Gross, 08/02/2020
- Re: [Coq-Club] Ltac2 Performance Question, jonikelee AT gmail.com, 08/02/2020
